’09 Cobalt – light body damage *finished pics pg9*
Home / Forums / Main Forum / Auto Body Repair / ’09 Cobalt – light body damage *finished pics pg9*
- This topic has 49 replies, 13 voices, and was last updated 13 years, 3 months ago by Nick Baker.
- September 17, 2011 at 3:24 am #32954
It can be avoided by.1.dont sand thru your clear.
2.spot prime your burn thrus.
3.spot seal your burn thrus.
4.use a hardener in your base coat.
5.apply one quick coat of 100% over reduced ready to spray clear BEFORE you apply base coat.
Now all you can do is stop and sand it out,spot prime,sand and try again or clear over it to seal it off and start over.September 17, 2011 at 3:27 am #329551. dont sand through the clear or
2. dust the first few coats of base on over the sand through or
3. prime or seal the sand throughs or
4. spray an overeduced coat of clear before basing to lock it all down or
5. use hardener in the base so if you do have to redo something and do sand through, it’s less likey to get softened by the reducerSeptember 17, 2011 at 8:18 pm #32969Jesus this is a shit ton of work to fix. Definitely won’t make this mistake again. :deadhorse
September 17, 2011 at 8:28 pm #32970[quote=”5LEater” post=22461]you americans be greatful you can still spray solvent.[/quote]
Whats your point :wak The only thing I miss about solvent is the speed,I sprayed it for 23 years,as far as color match and blending waterborne is better.If he was using waterborne he wouldn’t have had all the wrinkling problems :deadhorseSeptember 17, 2011 at 8:37 pm #32971[quote=”Amplified Details” post=22469]Jesus this is a shit ton of work to fix. Definitely won’t make this mistake again. :deadhorse[/quote]
Yes you will 😛
we all do :whistle:September 17, 2011 at 9:10 pm #32972[quote=”ding” post=22452]and now you are saying to yourself, “its just a Colbalt. Should have left it” :compsmash
But it could be worse, You could be bloverby and it could be a bronco :deadhorse :whistle:[/quote]
ur such a prick ding :rofl :rofl :rofl :rofl :rofl :rofl :rofl :rofl :roflSeptember 17, 2011 at 10:47 pm #32975I ain’t fighting a clear coat lift, Sealer bit me is the @$$. I was able to wipe mine off with thinner. :whistle: :blush:
September 17, 2011 at 11:14 pm #32976[quote=”bloverby” post=22475]I ain’t fighting a clear coat lift, Sealer bit me is the @$$. I was able to wipe mine off with thinner. :whistle: :blush:[/quote]
Were not talking about you Bloverby :pSeptember 17, 2011 at 11:15 pm #32977Dont listen to those guys Blov. They’re just being diks :whistle:
September 18, 2011 at 9:09 am #32980[quote=”ding” post=22477]Dont listen to those guys Blov. They’re just being diks :whistle:[/quote]
this!!!from the biggest peniswrinkle on the site come on u dorks can do better than this besides i bet blove has pics of his sordid tale of sealer on top of fresh base …..come on blove or as han use ta say pix pleze or the lift didn t happin :p :p - AuthorPosts
