1k vs 2k etch
Home / Forums / Main Forum / Paint and Refinish / 1k vs 2k etch
- This topic has 15 replies, 11 voices, and was last updated 11 years, 11 months ago by Dan.
- AnonymousJanuary 4, 2013 at 7:17 am #40134
I am wondering what the difference is between 1 and 2 part etch primers, do the aerosols actually compare to a 2 part etch. Ive been told they are the same but given the amount of BS my reps fed me so far I thought id toss it up here.
We have sprayed Dupont for over 15 years now and have been told by our reps that Dupont absolutely will not warranty anything that has any aerosol product on it. Even if its a Dupont aerosol. As for the product itself they don’t even compare. In my opinion the aerosols shouldn’t be used for anything other than minor break throughs on 1983 Honda Civics.
January 5, 2013 at 12:33 am #40149Couldn’t agree more.
I use a DeBeer 2 part etching primer over bare metal and this stuff really sticks! Even sanding with 80 grit it takes some getting off.
Where as the 1k aerosol and in the gun etch primers I have used always seem to come away quite easy, sometimes almost still sticky.
January 5, 2013 at 3:06 am #40157I dont believe the spray can stuff has anywhere near the same acid content as a 2 part etch. and I have seen first hand parts flash rust with spray can etch on them in just a matter of weeks
Everything I’ve been told makes me agree, 2k is the way to go.
But, in all fairness are all 1k etches the same? I would think that some may be a little better (less bad) than others. Plus, I think there are 2 types of aerosol etch primers. I’ve seen the common pigmented type that has a small amount of mil build (the stuff we’ve all used/abused at some point). Then ther is the aerosols with the etch that is transparent yellow and much more potent, with almost no solid content. I would think that this is much more like a true etch primer (but still inferior). Maybe I’m wrong, but I would think the 2 different products should not quite be grouped together.
I do not know of any paint company that would warranty them either, but every paint rep I’ve met I unofficially said that using it on very small burn throughs, within reason, is perfectly acceptable…even under waterborne.
January 5, 2013 at 9:23 pm #40168[quote=”Ben” post=29151]
I do not know of any paint company that would warranty them either, but every paint rep I’ve met I unofficially said that using it on very small burn throughs, within reason, is perfectly acceptable…even under waterborne.[/quote]
Maybe other paint comanies are different but when I took the sikkens WB certification course 4 years ago they specifically said “do not use autowave over any spray bomb etch (spray bomb or from a gun) or spraybomb filler primer.If you put sealer over top of the bomb stuff you would be ok but it kind of defeats the purpose.
[quote=”Jayson M” post=29153][quote=”Ben” post=29151]
Maybe other paint comanies are different but when I took the sikkens WB certification course 4 years ago they specifically said “do not use autowave over any spray bomb etch (spray bomb or from a gun) or spraybomb filler primer.If you put sealer over top of the bomb stuff you would be ok but it kind of defeats the purpose.[/quote]
PPG say to not use it their water either but my Rep did admit it would be fine to hit the cut thrus before water if your not using a sealer.
January 6, 2013 at 12:15 am #40173[quote=”smooth” post=29157][quote=”Jayson M” post=29153][quote=”Ben” post=29151]
PPG say to not use it their water either but my Rep did admit it would be fine to hit the cut thrus before water if your not using a sealer.[/quote]
Not a good idea, even on small spots. You would be better keeping a small amount of over reduced epoxy around for small spots.
January 6, 2013 at 1:20 am #40174Excellent idea Ryan I had forgotten about you mentioning that before.Do you over reduce it with sra and by how much?
I havent used a 2k etch primer in probably 5+ years, most of the old good ones arent compliant for use in canada anymore like the washprimer 1k CF(or was it 2k? Cant remeber). I remeber before compliance ppg had a really good 2k etch primer as well. Sikkens has recently discontinued or are in the process of discontinuing the aerosol 1kcf as well.. Now for the past 3 years have been using the Bonderite Auto-Prep wipes, which are supposidly better because its an actual conversion coating. Anyone else using the auto prep wipes or similar products?
[quote=”5LEater” post=29160]I havent used a 2k etch primer in probably 5+ years, most of the old good ones arent compliant for use in canada anymore like the washprimer 1k CF(or was it 2k? Cant remeber). I remeber before compliance ppg had a really good 2k etch primer as well. Sikkens has recently discontinued or are in the process of discontinuing the aerosol 1kcf as well.. Now for the past 3 years have been using the Bonderite Auto-Prep wipes, which are supposidly better because its an actual conversion coating. Anyone else using the auto prep wipes or similar products?[/quote]
Once you crack those wipes open..what is the theoretical life expectancy..or shelf life…are they a ‘one time use’deal?
[quote=”Charlie” post=29161][quote=”5LEater” post=29160]I havent used a 2k etch primer in probably 5+ years, most of the old good ones arent compliant for use in canada anymore like the washprimer 1k CF(or was it 2k? Cant remeber). I remeber before compliance ppg had a really good 2k etch primer as well. Sikkens has recently discontinued or are in the process of discontinuing the aerosol 1kcf as well.. Now for the past 3 years have been using the Bonderite Auto-Prep wipes, which are supposidly better because its an actual conversion coating. Anyone else using the auto prep wipes or similar products?[/quote]
Once you crack those wipes open..what is the theoretical life expectancy..or shelf life…are they a ‘one time use’deal?[/quote]
to be honest i couldnt tell you, I was told by a paint rep couple years ago that the wipes can be used multiple times.. so usually if the wipe I have used is still in good condition and still has plenty of product left on it I will throw it back in the container and re use..
I was using the wipes with Sikkens a as well. No issues that I was aware of. I used one wipe quite a bit before disposing of it. The container lasts a very long time. Just keep them sealed well.
Ryan, the Sikkens tech rep told me at one point that the aerosol primer would be ok for small areas…I know what you are saying, I’m just passing on what I was told…PPG DuPont and SW reps have all said the same. Again…not something I recommend, just things that have been said…
January 7, 2013 at 4:09 am #40197[quote=”5LEater” post=29160]I havent used a 2k etch primer in probably 5+ years, most of the old good ones arent compliant for use in canada anymore like the washprimer 1k CF(or was it 2k? Cant remeber). I remeber before compliance ppg had a really good 2k etch primer as well. Sikkens has recently discontinued or are in the process of discontinuing the aerosol 1kcf as well.. Now for the past 3 years have been using the Bonderite Auto-Prep wipes, which are supposidly better because its an actual conversion coating. Anyone else using the auto prep wipes or similar products?[/quote]
I still have been using the Sikkens 1kcf aerosol on bare metal areas before we put 2k on them. Havent heard anything about them discontinuing it down here. - AuthorPosts
