2007 Bandit
Home / Forums / Main Forum / Gallery / 2007 Bandit
- This topic has 7 replies, 5 voices, and was last updated 14 years, 4 months ago by james caruso.
- August 17, 2010 at 7:57 pm #23982
Hi,
Got this Suzuki in for a color change. Will paint it Corvette Atomic Orange.
The owner wants the brake calipers painted also, would a BC system hold up? do they really get that hot if you drive “normal”?Dag
[IMG]http://i204.photobucket.com/albums/bb126/dagges/DSC02565.jpg[/IMG]
[IMG]http://i204.photobucket.com/albums/bb126/dagges/DSC02562.jpg[/IMG]
[IMG]http://i204.photobucket.com/albums/bb126/dagges/DSC02556.jpg[/IMG]
it is fairly common for people to use Single Stage Urethanes on Engine blocks.
Which would probably be the route I would go.
Simply because with all the heat, and chip resistance you need. you want as little material on there as possible.I would probably go a coat or two of epoxy based Sealer. And Single stage right over that.
August 18, 2010 at 12:23 am #23988Thanks guys, I just bought some Delfleet epoxy F399 I will try that and BC/CC
Dag
August 18, 2010 at 2:19 am #23992single stage works good, base clear is fine as well. i have used both on bikes and cars. everyone here is on the right track. a sealer coat of epoxy first then base. i sell alot of small amounts of base to a local car customizing shop who probably does 1-6 set of car calipers a week. thats how i told those guys to do them and they all hold up great.
August 20, 2010 at 2:04 pm #24072I will paint it the Corvette Atomic Orange using PPG Deltron. It will be a bc/CC now this formula contains xirallic and my question is if the undercoat color will have any influence as when you paint a 3 stage?
Dag
August 20, 2010 at 2:12 pm #24073if i rememeber right, that formula has a ton of clear in it and doesn’t cover well in even the premium paint lines. i would say on that formula the undercoat color will definately have an effect on final color of the paint. i would make sure the base color is a nice solid very light grey or white. wouldn’t hurt to use a sealer under it.
