A few custom color’s been playing with
Home / Forums / Main Forum / Gallery / A few custom color’s been playing with
  • Anonymous
    August 2, 2009 at 1:13 am #15110
    Have a look here:
    http://www.refinishnetwork.com/jimmo-paint-jobs/custom-paint-colors.html
    August 2, 2009 at 6:03 am #15112
    Have you tried spatter painting? Turn your pressure down and let the paint spit out. It could make for some cool effects too.
    August 2, 2009 at 6:44 am #15115
    [b]AAE wrote:[/b]
    [quote]Have you tried spatter painting? Turn your pressure down and let the paint spit out. It could make for some cool effects too.[/quote]
    in the lacquer days 👿 they used to do cobbwebbing. This panel was done with unreduced base coat in a gravity feed gun turned down to about 1-2psi
    http://www.paintbyding.com/cobbweb-panel.jpg
    August 2, 2009 at 6:45 am #15116
    Not yet, the next thing i’m gonna try is a granite. Just playing around, I’ll try some splattering. Have an airbrush on order now too.
    August 2, 2009 at 7:54 am #15118
    Looks cool.
    You might be spraying counter tops before long! :cheer:
    August 2, 2009 at 3:21 pm #15120
    here is some refrence for you for the granite.
    [IMG]http://i104.photobucket.com/albums/m192/xtremek6/knotwork1.jpg[/IMG]
    [IMG]http://i104.photobucket.com/albums/m192/xtremek6/knotwork2.jpg[/IMG]
    turn the psi way down. mix 3 shades of grey sort of close in color, spatter them on. then mix some intercoat clear with hok sparkle white pearl and do the same. the bc1190 cut down with some bc100 may work as well but have not tried it. i know you have that right on your rack so it would be easier for you. the key to make it believeable is your color choices on the grey and getting the pearl spattered on right. you should get an actual piece of granite for a sample.
    August 2, 2009 at 4:29 pm #15121
    That looks awesome Jim. Thanks!
    Carizzma colors are a lot easier for me to get, do you know much about that line? Using diamont for what I can is easier but I’d like to bring in carizzma eventually. For now I was thinking of just grabbing a few of the common one (if theres such a thing). I do need to come up with a funky red for the top of a boat, any thoughts on that?
    August 5, 2009 at 1:50 am #15173
    I’ve got my rep stopping by tommorow with some carrizma & to help me a bit, so hopefully i’ll have a few more sprayouts to post.
    August 5, 2009 at 1:59 am #15174
    does look damn good … I done some granite/cement jobs before and that looks sweet jim ….. good job
