ANTI STATIC
  • June 25, 2012 at 2:06 pm #37481
    Does anyone know if there are any type of anti static wipes that can be used after tack clothing prior to application of base.
    Just trying to make sure that the panels and body I have to paint are not charged up .
    Any comments from those members out there that spend most of there working weeks in the booth.
    Cheers
    John
    Elite Rides Garage :cheer:
    June 25, 2012 at 5:08 pm #37483
    There are several products out there. Sikkens has an antistatic cleaner. Having a little extra humidity in the booth seems to prevent static from getting worse while spraying. I know some guys will ground their metal parts.
    I haven’t tried these Devilbiss wipes, but I’d like to: [url=http://www.autorefinishdevilbiss.com/DesktopModules/Bring2mind/DMX/Download.aspx?Command=Core_Download&EntryId=881&PortalId=0&TabId=86][/url]
    June 25, 2012 at 5:32 pm #37485
    Anything you wipe the object with between tacking and base is a risk.
    Like Ben already mentioned, grounding may be an option.
    June 26, 2012 at 2:50 am #37488
    you can mist a coat of ppg DX103 on the parts.
    June 26, 2012 at 9:21 am #37494
    Thanks Ding,
    I’ll get some DX103 and give it a try.
    June 26, 2012 at 9:45 am #37496
    Yep, as mentioned, ground the body to the booth floor with a heavy chain. You can wrap the chain around the diff if your painting a roller.
