any advice
Home / Forums / Main Forum / Paint and Refinish / any advice
- This topic has 5 replies, 5 voices, and was last updated 13 years, 2 months ago by Ben Hart.
- October 20, 2011 at 1:34 am #33680
about to go to ppg water/been to the class/now i need to know from the vets about the do’s and don’ts/any tips would be greatly appreciated/thanks
great color matches if you can find the right variant in the decks. The SG-0 sealers are great and they lay down very flat. Base has great coverage and never require any more than 2 coats when use the correct sealer. Blends very easily , Control coats are a breeze. The ms clear in nexa aquabase system is nothing to right home to mom about but i love the HS. Once you get used to the system you wont have any complaints. IMO.
I sprayed Enviro for a short while. The clear is definately the weak link. The sealer is awesome (and incredibly flat), the base is very easy to use. Just make sure it has dried off well before clearing.
Only advice with the base is to follow the tech sheet, I don’t think there’s any surprises with this stuff.
October 21, 2011 at 6:08 am #33700like the others said, spray it exactly the way the instructors tell you.
October 21, 2011 at 7:25 pm #33701Stay away from the EHP clears EC700/750. If you need a low VOC clear go with Deltron DC4010 if you can.
[quote=”dcturcotte” post=23157]Stay away from the EHP clears EC700/750. If you need a low VOC clear go with Deltron DC4010 if you can.[/quote]
We used them both. The DC is a lot easier to use, but if you can get it dialed in right, I think you can get a nicer/deeper finish with the 700/750.
