Anyone spray clear with a 1.6?
Home / Forums / Main Forum / Paint and Refinish / Anyone spray clear with a 1.6?
- This topic has 14 replies, 3 voices, and was last updated 10 years ago by Jon.
so I bought a Sata 4000b rp off craigslist the other day, somehow didn’t realize the gun has a 1.6 tip instead of 1.3 as I’ve always used… Anyone shoot clear with this setup? The tech sheets on the clears I’m using say to use 1.3 – 1.6 I’m gonna try some tests n see how it works for me otherwise I may try to re sell it
Ya I use the te20 for hs clear and the te10 for ms clears I love my pro lite been spraying with it since it came out but I just wanna try something new. I doubt this 4000 will be slow since the 1.6 is so large im sure I’m gonna have to turn the fluid down some I just wonder how atomization is going to be. ill let you know what I think of the speed and quality of the finish once I find some time to do some test panels with it
December 3, 2014 at 8:19 am #48026You could keep your eyes on ebay for a nozzle set,now that the new 5000’s are out you can probably get 4000 parts a bit cheaper like a 1.3 or a 1.4 for $150-$200.If the gun is in nice shape I would just change the nozzle set,if you do get a used gun you always run the risk of it being clapped out.
You could also run it at 32 psi and turn the material knob in a turn or so and see how it goes,not ideal but it will work.The 4000 is not as fast as the earlier versions but its not super slow either,it does lay down a smooth finish.A 1.4 in a 4000 is comparable to a 1.3 in the 3000,it really depends how you like to spray and either one will work fine.You could also just sell it and get what you want or get a new 5000,I have been spraying with one for the last 3 weeks and have been pretty happy with it.
December 3, 2014 at 10:18 am #48028Yes a 1.4 in a new 5000,I prefer a 1.4 in all variations of the RP for sikkens.
So I’ve used the 4000 at 32 psi with the fluid turned in one full turn from full fluid like you recommended jayson and I’m actually getting really good results with the gun I’m surprised it still lays it down so smooth with such a large tip and nozzle. Thanks! I’m still eventually gonna get the 1.3 nozzle set when I have the extra cash but in the mean time I don’t even see a reason too haha
December 10, 2014 at 4:19 am #48057Cool glad I could help :cheers Depending on what materials you use a 1.4 might work also.The 4000’s don’t put out as much material as the older versions so a 1.4 might just work for ya if you can handle a 1.6.
I spray all ppg products deltron base and for clears I use jc60 on cheap stuff and jc630 and the shopline euro clear on nicer jobs Your right the 1.4 might be better off for me since I’m already spraying it with a 1.6 I just figured I’d go 1.3 cause that’s what I’ve always sprayed clear with on my tekna pro lite
