Base coat gun recommendations
Home / Forums / Main Forum / Paint and Refinish / Base coat gun recommendations
- This topic has 52 replies, 17 voices, and was last updated 11 years, 9 months ago by Danny.
- January 10, 2013 at 7:22 pm #40268
Hey I use devilbiss pro with 1.3 and I love it 🙂 even better with my new pro lite , u can’t go wrong with them
January 10, 2013 at 10:24 pm #40275Yep, I use a Devilbiss Gti Pro 1.3/1.4 for base with a T1 aircap and its spot on.
Not sure if the aircaps are named different in different countries.
January 10, 2013 at 10:33 pm #40276[quote=”JackMarshall” post=29260]Yep, I use a Devilbiss Gti Pro 1.3/1.4 for base with a T1 aircap and its spot on.
Not sure if the aircaps are named different in different countries.[/quote]
If I remember rightly the t2 is for the fast flow which lays the material down with a ( original) finish lol and the t1 give a nice show room glass finish.if you use them for clear like I do, I’ve never used the t1 for color which is interesting as I use iwata w400 for color wonder how they would compare :lol1
January 11, 2013 at 6:47 am #40280[quote=”hating-painting” post=29252]I just picked up a Tekna that my jobber had on special. $325.
1.2,1.3,1.4 needles and a digital regulator.
Looking forward to trying it out today..I have been spraying with a Devilbiss GTI. GTI’s are pretty reasonable.[/quote]
How did the tekna work out for you ?They are very impressive guns for a very reasonable price.
[quote=”Xchaser” post=29274][quote=”ARTSPRAY” post=29264]i use a Walcom Geo ,sensational for blends[/quote]
Hey Paul you still using the fx model geo? What setup you got in it?[/quote]actualy although min
e is a gravity model it isnt marked as an FX but an FZ which when you look should be the suction version ?? that apart as i mostly do bikes i set mine up witha 1.2 however i have done large completes with it and vans ,i have also seen sensational results with clear using a 1.5 set up ,one i sold which wasa 1.4 my friend dedicated to just waterbase so all in all they are a very versatile gun but admitidly a bit slower than the HA when dealing with HS clears etc etcthe other usefull thing about a Geo is its astonishingly low air consumption as low as 7.5 CFM depending on the set up used ,so when compared to say a Sata HVLP your running costs are cut in half compresser wise ,transfer rates on all the walcom range are above 70% but most importantly the finish quality is always superb imo
i know i rattle on about Walcom guns but they are priced well and the quality of the guns are at least as good as any other top marque
BTW the Geo also has the option of a titanium nozzle reputed to be ten times more durable then the standard Inox SS nozzles
January 11, 2013 at 11:04 pm #40295[quote=”rikka23″ post=29261][quote=”JackMarshall” post=29260]Yep, I use a Devilbiss Gti Pro 1.3/1.4 for base with a T1 aircap and its spot on.
If I remember rightly the t2 is for the fast flow which lays the material down with a ( original) finish lol and the t1 give a nice show room glass finish.if you use them for clear like I do, I’ve never used the t1 for color which is interesting as I use iwata w400 for color wonder how they would compare :lol1[/quote]
T2 is fast flow for gloss/clears T1 is suited to solvent basecoat. I have tried the T1 for clear and it does not work well.
T110 is the latest aircap for the standard gti for HS clears and glosses which is superb.
January 11, 2013 at 11:26 pm #40298[quote=”ARTSPRAY” post=29264]i use a Walcom Geo ,sensational for blends[/quote]
Any links to where I could pick one up in the UK?
I’ve seen you mention them before but couldn’t find a dealer. The low air consumption in particular interests me, especially since I’ve moved to working mobile for a bit so need to keep air usage as low as I can.
[quote=”Jayson M” post=29265][quote=”hating-painting” post=29252]I just picked up a Tekna that my jobber had on special. $325.
How did the tekna work out for you ?They are very impressive guns for a very reasonable price.[/quote]
Waiting on the bodymen to finish something up. Maybe Monday.
Gold Honda and a Gray/purple Met (code T8) Mustang coming.
I will be puting to the test.[quote=”ARTSPRAY” post=29286]i know they where at one time sold by Brown Brothers who may be able to asisit in directing you to a current dealer ,i did find some suction versions going on ebay 1.5 and they have accepted offers of £50 on them ,a total steal ;-)[/quote
Paul do you think an iwata wbx would be any good for base coat, I know you’ve mentioned that they use them for clear, painting Aston martins what are your thoughts? :huh:[quote=”ARTSPRAY” post=29286]i know they where at one time sold by Brown Brothers who may be able to asisit in directing you to a current dealer ,i did find some suction versions going on ebay 1.5 and they have accepted offers of £50 on them ,a total steal ;-)[/quote]
