Baseball bat paint job – got input?
Home / Forums / Main Forum / Gallery / Baseball bat paint job – got input?
- This topic has 11 replies, 6 voices, and was last updated 16 years ago by Stone.
- AnonymousAugust 25, 2009 at 9:25 pm #15514
Just wondering if anyone has some input on my latest project, a baseball bat. Here is the article:
http://www.refinishnetwork.com/blog/painting-an-aluminum-baseball-softball-bat.html
any suggestions are welcome. My rep tells me I should not use a flex additive as I thought as it decreases the mar resistance. Any idea’s to make the lettering easier for me would be nice, not something I know much about.
:blink:
Something designed to take a beating?In all honesty, I wouldn’t touch it with anything more than industrial Single Stage. Preferably a soft enamel.
You go with Primer/Base/Clear, I think you’re going to get too much Brittle Film Build. and she’ll chip on you.
At least with the soft Enamel the paint will dent instead of chipping off.
What do they use originally on those things?
Seems like a transparent anodizing or something. :SAugust 25, 2009 at 10:20 pm #15518i agree, probably no base clear. stick with ss. uno or 22 should work out pretty good.
AnonymousAugust 25, 2009 at 10:31 pm #15519I actually seen an episode of how it’s made (I’ll see if i can pull the clip, think there available online) and they said it was a polyurethane clear coat applied. Think about goalie masks? I’ve seen a ton of guys do them and you have pucks impacting them twice as hard as a softball. They seem to hold up ok. I’m gonna try base/clear since it’s what I have and am just using run-off materials on it. It’s a cheapy bat, don’t want to order in anything special on this one. Thanks for the input though, maybe if I do a higher end one.
August 26, 2009 at 1:28 am #15524if your good with a razor you can put some spray mask on it then cut the letters out. transfer tape will also work but you probably have some spray mask there. or have a sign shop cut you out a stencil
AnonymousAugust 26, 2009 at 4:19 am #15532Sounds like interesting stuff pnlbtr,
this is what I did for my lettering:
[img]http://img43.imageshack.us/img43/6657/dsc01647z.jpg[/img]
I should really invest in some transfer tape, just threw down some 2″. I have no clue what I’m doing here…sign shop eh,,, that sounds like a good idea, how much do they charge to make you a good stencil?
AnonymousAugust 26, 2009 at 4:20 am #15533here’s a better pic of the cutout:
[img]http://img23.imageshack.us/img23/8352/dsc01650vjk.jpg[/img]
AnonymousAugust 26, 2009 at 8:44 pm #15538Here is what I have now:
[img]http://refinishnetwork.com/imagehost/image.php?id=E4B3_4A9563AD[/img]
I’ve just cleared it and was thinking of touching up some rough edges with a brush by hand and reclearing/sanding a few times after. What do you think?
AnonymousAugust 27, 2009 at 3:20 am #15549Touched it up and it all worked out, ended up changing the middle stripe color, here is the final result:
[img]http://refinishnetwork.com/imagehost/image.php?id=5CC3_4A95C0E1[/img]
August 27, 2009 at 4:39 am #15551looks nice. now if it will help you hit the ball then it will be a good thing :rofl
