Best way to clean window rubber/moldings
Home / Forums / Main Forum / Paint and Refinish / Best way to clean window rubber/moldings
  • September 13, 2012 at 7:35 pm #38270
    I recently took in a car to be painted all over. The car had been previously painted and the masking left a lot of rubbers and moldings painted and covered in over spray. What is a good way to clean the paint and over spray off the soft rubber areas such as around windows and doors. I have tried thinners and scraping with a knife or blade but is time consuming. Is there a product or technique that would do the job quicker and cleaner?
    September 13, 2012 at 11:09 pm #38274
    Gun Wash and elbow grease 😉
    September 14, 2012 at 1:40 am #38275
    you can try a steel wool pad. might scratch so test it first. when it becomes too difficult i replace them but they are sometimes pricey.
    September 14, 2012 at 5:27 am #38283
    lacquer thinner, white scotchbrite
    September 15, 2012 at 10:26 am #38296
    If they are the soft type rubbers that lift away from the body slightly, I use a filler/bondo spreader to lift the rubber away and protect surrounding paintwork and use a red/grey scotchbrite to take it off.
    Try a small area first though as sometimes the scotchbrite is too aggressive and tears the rubber up.
    September 15, 2012 at 9:24 pm #38298
    [quote=”JackMarshall” post=27426]If they are the soft type rubbers that lift away from the body slightly, I use a filler/bondo spreader to lift the rubber away and protect surrounding paintwork and use a red/grey scotchbrite to take it off.
    Try a small area first though as sometimes the scotchbrite is too aggressive and tears the rubber up.[/quote]
    that’s why I use a white scotch brite. maybe 0000 steel wool.
    I have them around for tint work.
