Best way to tint clear coat black.
Home / Forums / Main Forum / Paint and Refinish / Best way to tint clear coat black.
  • September 25, 2012 at 1:02 pm #38374
    I’m curious what you pros are doing to smoke PC light housings.
    Seems, from what I’ve heard, the industry standard varies a bit from place to place. Some guys just buzz down the plastic with 600 and blast some clear with a little black base mixed in. Others sand up to 1000 or 1200 and use black candy. Others yet prefer the film when possible, and only spray when necessary.
    Personally, I want to spray them. And not just shoot them, but gain the benefits of shooting them. I mean nice even color, perfect sand prep off the car, and a nice build of clear on top so they can be polished later without affecting the tint.
    I’m curious about black tint instead of base. I don’t mix anything, so I’m just grasping at straws here. Is there any advantage to this over base? I’m using a fast, spot panel clear from MS. Seems to work pretty well.
    So what’s your method?
    September 25, 2012 at 4:31 pm #38377
    Using a black candy will give a better appearance. Regular basecoat toners use a carbon black pigment that is milled for the basecoat. A candy is a dye which lets it transmit more light and keep a cleaner appearance. Using just a toner will let less light through and can give it a bit of a dirty look if the wrong toner is chosen.
    If you go the candy route some can be a bit too blue and need a drop of a gold/yellow candy to get the purple out of it.
    October 1, 2012 at 9:40 am #38442
    Awesome. Thanks
    I know some guys just dump a little black base coat in with the clear. Is there anything wrong with that?
    Candy is friggin expensive…
    October 1, 2012 at 5:00 pm #38443
    I would say just put a few drops of black and put 2 or 3 coats and if I need to I will reclear with regular clear thus will help give it a deeper black look also
    October 1, 2012 at 8:56 pm #38446
    Can’t get candy here so I mixed 3% black base into a mix of 1 part ppg color blender D895 and 2 parts Reducer sprayed 4 thin coats then 2 coats of clear.
    [IMG]http://i204.photobucket.com/albums/bb126/dagges/DSC04118-Copy.jpg[/IMG]
    [IMG]http://i204.photobucket.com/albums/bb126/dagges/DSC04140.jpg[/IMG]
    [IMG]http://i204.photobucket.com/albums/bb126/dagges/DSC04146-Copy.jpg[/IMG]
    [IMG]http://i204.photobucket.com/albums/bb126/dagges/DSC04147.jpg[/IMG]
    October 8, 2012 at 1:08 pm #38528
    [quote=”Painterman1″ post=27568]I would say just put a few drops of black and put 2 or 3 coats and if I need to I will reclear with regular clear thus will help give it a deeper black look also[/quote]
    black base? I’ve never actually used black base, just shot SS black urethane and cleared it when necessary.
    How long does solvent base last anyway? I might have a quart on the shelf for an awful long time…..
    October 8, 2012 at 1:08 pm #38530
    Dag, that looks real nice.
    October 9, 2012 at 5:41 am #38533
    Yea thats what I’ve always done I haven’t had any issues
