Blister in HD tank
Home / Forums / Main Forum / Paint and Refinish / Blister in HD tank
- This topic has 7 replies, 6 voices, and was last updated 16 years, 3 months ago by jackcarlson.
- May 22, 2010 at 11:56 am #21450
Hi,
Painted this about 6 months ago and after 3 this started to apear.
[IMG]http://i204.photobucket.com/albums/bb126/dagges/P1100202.jpg[/IMG]
[IMG]http://i204.photobucket.com/albums/bb126/dagges/P1100211.jpg[/IMG]
[IMG]http://i204.photobucket.com/albums/bb126/dagges/DSC01972.jpg[/IMG]
[IMG]http://i204.photobucket.com/albums/bb126/dagges/DSC01971.jpg[/IMG]
I guess it must be a small pinhole or did I scr… it up? If a pinhole what can I use to seal the tank?
Dag
May 22, 2010 at 3:42 pm #21456if it’s a pinhole you will want to weld it up. any kind of sealing is just a band-aid. but its also possible that gas fumes got under the paint from around the filler hole. however that would usually show damage by the gas cap first. I see a stain where the paint has been removed. can you see any sign of where the tank has been leaking.
May 22, 2010 at 4:34 pm #21457The stain is from my mechanic, I can’t se any place were it could have gone underneath. I will have the area sandblasted and see if I can fins something.
May 23, 2010 at 5:50 am #21510absolutely, seen it a ton of times and always looks the same. you definately have a pinhole there. no sealer. it needs to be welded then pressure tested.
