booth preasure?
Home / Forums / Product Reviews / Equiptment / Tools / booth preasure?
- This topic has 9 replies, 4 voices, and was last updated 12 years, 6 months ago by Andy Taylor.
- June 2, 2012 at 12:03 am #37079
You’re from the UK aren’t you reidy? In which case regulations say you have to run it at a slight negative pressure to keep the harmful fumes from escaping. Our booth even shuts down automatically if it strays into positive pressure for too long!
As Ben says though, slightly positive is a much better idea and I think that’s how most US booths run, but since the regulations here don’t allow it 0 is about the best you can do 😉
[quote=”Andy T” post=26349]You’re from the UK aren’t you reidy? In which case regulations say you have to run it at a slight negative pressure to keep the harmful fumes from escaping. Our booth even shuts down automatically if it strays into positive pressure for too long!
As Ben says though, slightly positive is a much better idea and I think that’s how most US booths run, but since the regulations here don’t allow it 0 is about the best you can do ;)[/quote]
I understand the point for voc emissions, but if your booth is decently sealed, then it really shouldn’t make a difference. That’s just plain stupid :wak
I wonder if that is why on the spraybake booths we had, it was non-adjustable?
June 2, 2012 at 10:21 am #37089Who said rules & regs had to make sense 😆
Some years ago I worked in a Spraybake and that wasn’t adjustable either. It was bought second hand, and when they came to fit it we were told it had to be “upgraded” to include a pressure gauge, even though there was no form of adjustment if the pressure was wrong :huh:
Hi. Thanks for replys. Havent got any pics of control panel but guy who installed it said it is adjustable, he suggested leavin it at 0. Control panel has 2 small controllers on top left corner one for spray temp and one for bake temp, then it has red emergency stop button on right top corner, below it is booth pressure gauge, and bottom left is small digital screen with buttons below to control bake,spray, burner, lights etc-
June 16, 2012 at 8:02 am #37210Actually due to EPA rules here in the states, we also are mandated to run slight negative pressure. The days of nice clean jobs and a slight positive pressure are over….
June 16, 2012 at 8:04 am #37211[quote=”Andy T” post=26359]Who said rules & regs had to make sense 😆
Some years ago I worked in a Spraybake and that wasn’t adjustable either. It was bought second hand, and when they came to fit it we were told it had to be “upgraded” to include a pressure gauge, even though there was no form of adjustment if the pressure was wrong :huh:[/quote]
There’s always an adjustment, just let the filters plug up well, you’ll be running positive in no time. :dnc
June 17, 2012 at 11:43 pm #37270Yep, that’s it.
The differences are only small, but that’s the basic rule. Positive pressure will tend to blow out of any slight leaks in your booth, negative will tend to suck in (bringing the dust in with it!)
