BRAKE CALIPER PAINTING WITH SIKKENS AUTOWAVE?
Home / Forums / Main Forum / Introductions / BRAKE CALIPER PAINTING WITH SIKKENS AUTOWAVE?
  • August 1, 2013 at 6:17 am #43858
    HAS ANYONE PAINTED BRAKE CALIPERS WITH SIKKENS AUTOWAVE AND CLEARED WITH SIKKENS 2 PACK CLEAR? I NEED AROUND 3 TO 500 TEMP RANGE
    August 1, 2013 at 7:41 am #43859
    I would like to say you will probably be fine. 500 degrees is probably pushing it a little far though. Is this some high performance application that is going to he seeing this much heat?
    Your best bet is to contact Akzo and find out. I would also be concerned about how the base and undercoats will react to the high temp and rapid repeated heating/cooling cycles.
    August 1, 2013 at 2:35 pm #43860
    In high temp areas I like POR15 clear. Funny thing though once you open the can and close it, it is so hard to reopen.
    August 1, 2013 at 2:38 pm #43861
    I think your clear will turn out to yellow a lot and the base will become darker ( don“t know if that is the correct way to say it ) , so even if you do a color match on the car it will look a lot different later on.
    We powdercoat these kind of things wich is much more durable and temperature resistand.
