Bronze color code
Home / Forums / Main Forum / Paint and Refinish / Bronze color code
- This topic has 7 replies, 5 voices, and was last updated 11 years, 7 months ago by Simon Richards.
- AnonymousMay 6, 2013 at 2:37 pm #43094
Howdy,
Got a request to repaint a Kawasaki 1400 GTR in Magnesium Metallic Grey code 27Y.Unfortunately the ppg dealer can’t mix the mid coat.
any sugestions to another color like this one?[URL=http://s204.photobucket.com/user/dagges/media/30263_0_4_4_140020gtr_Image20credits20-20Kawasaki_zpsce05d20b.jpg.html][IMG]http://i204.photobucket.com/albums/bb126/dagges/30263_0_4_4_140020gtr_Image20credits20-20Kawasaki_zpsce05d20b.jpg[/IMG][/URL]
Dag
May 7, 2013 at 2:14 am #43098Its a limited use toner in the global line. Looks like it’s avail in waterborne as well. I didnt get a warning about the toner for water. maybe it woul be better to see if you could get it mixed that way
May 7, 2013 at 4:15 am #43103Thank’s, but he don’t sell water yet. He has the Deltron Global system. Is there a on-line site where I can see the formulas myself?
Dag
May 7, 2013 at 4:20 am #43104http://www.ppg.com/coatings/refinishmiddleeast/Collision/Colour/Pages/1220_Online%20Colour.aspx
You have to register for the online color access
May 8, 2013 at 12:56 pm #43125Dag, here’s the Deltron GRS formula for 1000ml of each layer
[b]
Basecoat/Main layer[/b]D989 Coarse silver aluminium 530.4gm
D789 Jet Black 250.2gm
D740 Black 150.1gm
D759 Matting base 15.0gm[b]Tinted Clearcoat[/b]
D895 Colourblender 881.2gm
DH995 Red to Gold 22.0gm (Limited use tinter)
D759 Matting base 22.0gmMaybe you could substitute the red to gold with some red pearl and some gold pearl powder?
Hope this info helps you?
May 8, 2013 at 8:57 pm #43132Thank you Paintwerks! I will see with the owner if he want me to make a tryout.
I have never sprayed a pearl mid coat before, how many coats can I expect to shoot 2-3?Dag
May 9, 2013 at 3:28 am #43136Dag, you’re very welcome! Happy to help out a fellow painter. 🙂
With a tri-stage (3 layer) paint, you spray the main layer to full saturation (anywhere from 3-7 coats depending on gun setup and whether in this case if you’ve used the G7 greymatic coats first).
In the mid/effect layer (the tinted colour blender), you’ll need to spray anywhere from 2-4 coats with 5-10 min flash off. If you’re painting the whole bike, it’s a little easier because you don’t have to match anything else, and then about 3 coats should be just right. But if you are matching, you’ll need to do 4 spray out cards, with the cards having 1,2,3 and 4 coats of the pearl mid coat (after each card has had the main layer applied). Then you need to clear coat all the cards with the same product and material thickness you’ll be using on the job. Then you can eye match.
Btw, if you need to tint, only tint the main layer.
One last thing….because you are applying quite a lot of coats of base, don’t clearcoat right at the end of the 15 minute final flash off period. Let the panels sit for at least an hour, preferably 2 before clearcoat. This will allow adequate time for proper flash off (especially if one doesn’t have a spray booth with constant airflow over the parts).
Hope this helps.
Cheers,
Simon - AuthorPosts
