Building a a mini ‘shop!
Home / Forums / Main Forum / Gallery / Building a a mini ‘shop!
  • March 7, 2013 at 6:03 am #41915
    Well i just thought i’d post up some pics of the home shop i’m building for small jobs, bumpers and things like that.
    started out like this:
    [IMG]http://i91.photobucket.com/albums/k299/johnmaloney88/2012-12-27160925_zps9a8b63b3.jpg[/IMG]
    i bought 50mm cold room insulation with white panelling and used this on the roof and walls. if i run the diesel heater for 5 minutes now the place is lovely and warm for painting!
    then went a bit like this:
    [IMG]http://i91.photobucket.com/albums/k299/johnmaloney88/2013-02-22153559_zps6c122863.jpg[/IMG]
    then i got some lights in and my father tried to move in doing woodwork! :headsmack:
    [IMG]http://i91.photobucket.com/albums/k299/johnmaloney88/2013-03-04140005_zps4b4f6e70.jpg[/IMG]
    then we built a bench
    [IMG]http://i91.photobucket.com/albums/k299/johnmaloney88/2013-02-27151723_zpsf826e704.jpg[/IMG]
    then i started work on an old tractor, stupid fibreglass panels!!!
    [IMG]http://i91.photobucket.com/albums/k299/johnmaloney88/2013-03-06113123_zps68e0d524.jpg[/IMG]
    April 3, 2013 at 5:03 pm #42568
    looks like a nice place you have there !
    April 3, 2013 at 6:41 pm #42571
    Be Careful with that diesel heater, may cause airborne contamination(fisheyes). Other than that it looks good, remember that the sky’s the limit.
    April 3, 2013 at 11:32 pm #42574
    [quote=”smooth” post=31415]Be Careful with that diesel heater, may cause airborne contamination(fisheyes). Other than that it looks good, remember that the sky’s the limit.[/quote]
    Cheers dude, i was recently told the same thing. what would u suggest to use instead?
    April 4, 2013 at 3:24 am #42579
    I have an oil furnace in my shop, its gets expensive during the winter but its a good consistent heat and allows me to get the booth temp. to 30 degrees. all you need to do is build a furnace room up to code and run ductwork to different areas of the shop.
