bumper removal
Back to: Auto Body Repair2 Replies
Home / Forums / Main Forum / Auto Body Repair / bumper removal
- This topic has 2 replies, 2 voices, and was last updated 15 years, 4 months ago by Kent Buehrer.
- August 18, 2009 at 2:55 am #15394
Do you guys have any tricks on how to remove bumpers quickly? I was working on a new Malibu and the only way to get it off is to get a honking long extension to remove the bolts from underneath. Also, can you recommend a combination set of fasteners?
Thanks,
KentAnonymousAugust 18, 2009 at 3:05 am #15395I’m afraid that’s just the GM way, 100 bolts to keep the bumpers on. Usually a handfull of 10 mm bolts & a few push clips.What bumper are you taking off, front or rear?
August 18, 2009 at 3:59 am #15399As a mobile painter I don’t fully remove the bumper but want to be able to loosen it enough to scuff the normally inaccessible areas. From what I have seen, the Jeeps are hard too. They all seem to have rivets in the wheel wells holding it together.
