Can some explain correct use of Foam Tape
Home / Forums / Main Forum / Paint and Refinish / Can some explain correct use of Foam Tape
- This topic has 3 replies, 4 voices, and was last updated 13 years, 11 months ago by Ben Hart.
- October 18, 2011 at 11:14 pm #33640
Have a look here.
[video]http://www.youtube.com/watch?v=xVN1ty4gX2A[/video]
I’ve used this on touch ups and had excellent results.
Craig
[quote=”ste” post=23095]everytime i use the foam tape in a jamb…specifically on the quarters i get a paint line. whats the proper way to mask the quarter without getting a paintline?[/quote]
On the 1/4, make sure the tape is inside the jamb far enough (say a good 1/4″ in from the edge). Gun pressure is a good factor, the higher the PSI, the deeper the paint will get giving you a sharper edge. Also beware of how the tape sits, the the adhesive part is too far out, it won’t allow the paint to go in underneath properly for that soft finish.
You probably wont ever get 100% prefect edges, but they should come out pretty darn good. When I use foam tape, I like to unmask as soon as the bake cycle is done to inspect the edge. If there is a slight sharpness to it, I will take a rag with a small amount of thinner and wipe it, this will smooth out that sharp edge. Alternately, you can knock it down with ultra fine paper after wards (1000-1500 grit).
