Candy paint
Home / Forums / Main Forum / Paint and Refinish / Candy paint
- This topic has 5 replies, 3 voices, and was last updated 14 years ago by Ben Hart.
- December 20, 2010 at 10:43 pm #26320
Howdy,
I can’t get candy paint locally, so I was wondering if I can use some transparent toners and mix in color blender to get a similar effect?
Dag
First off, I have never done this…
But in theory it should work. A clear basecoat with a little toner would be better for depth than just basecoat blender, I think. You are using PPG aren’t you? The only issues I see are playing with it to get the right effect, adhesion and extended flash times.
You can’t get it ordered from elsewhere? What sort of a colour are you trying to mix.
December 21, 2010 at 3:35 am #26324it will work. wont be exactly the same but you can play with it some. the biggest issue with the toners is eventually they will work towards coverage as thats what they were made for. the end result probably wont be as clean as using candy dyes
December 21, 2010 at 12:13 pm #26331Thanks, I will try it out when the PPG rep is back from Holiday.
I will also try to order some but it’s a hassle to get anything here and out of custom… I would like to try some blue and red.
The local painters ask about $100-200 to paint a car and I can’t compete with that so what I would like to try is some
specially effect paint and things like that.Dag
December 21, 2010 at 4:44 pm #26334ppg makes candy dies as well. DMX toners in their radiance 2 line. talk to your rep. he should be able to get some
[quote=”Dag” post=16342]Thanks, I will try it out when the PPG rep is back from Holiday.
specially effect paint and things like that.Dag[/quote]
You would be lucky to buy enough paint for a car, here, for $200.
Blues and reds should be good colours to work with, being as many of their toners are somewhat translucent. Keep us posted on how this works out for you!
