can’t bleed with PPS
Home / Forums / Main Forum / Paint and Refinish / can’t bleed with PPS
  • July 28, 2010 at 10:09 pm #23374
    Hi,
    i stop bleeding air with 3M PPS system because when i spray, my gun can’t work fine. If i don’t bleeding, it’s ok. Any comment about that ?
    July 28, 2010 at 11:01 pm #23375
    What type of gun, what pressure are you spraying with? Does it do that with all materials (base, clear, primers, etc)? Are you using the coarse or fine filter/caps?
    The newer liners are a little thicker than the older ones, I believe, and so it may take a little more pressure to create the vacuum need to pull the product through. But it shouldn’t make it difficult to spray…
    July 28, 2010 at 11:05 pm #23376
    I have never done the bleeding part. Just hook it up and spray.
    I dont really think collapsing the liner is a good thing. It will restrict paint flow.
    July 28, 2010 at 11:11 pm #23377
    I very rarely bleed the air out too. Only when it’s really necessary like painting the underside of a bumper cover or sill (rocker panel?), when the gun will be tilted right on it’s side or even upside down.
    July 29, 2010 at 1:22 am #23381
    I use it for Primer and basecoat. Anyway, yes i don’t have to spray upside down.
    thanks for your comments
