Clear Coat sand through
Home / Forums / Main Forum / Paint and Refinish / Clear Coat sand through
  • June 26, 2012 at 6:18 pm #37498
    New paint job and had a bad run in the clear..Did the ultimate sin and sanded through to the paint. What is the proper way of repairing this? Still have good base underneath, can I spray this area again and reclear the pannel?
    June 26, 2012 at 6:51 pm #37499
    Are you using waterborn or solvent???
    June 26, 2012 at 6:59 pm #37500
    solvent
    June 27, 2012 at 3:18 am #37502
    I’d (block) sand it down, prime, block and paint if you want to eliminate the possibility of seeing it again after you respray. :chair
    June 27, 2012 at 5:10 am #37503
    Yep, as Jimmo said, that is the safest bet. Priming will also eliminate the chance of any wrinkling/issues re-baseing over your fresh paint.
    June 28, 2012 at 4:28 am #37509
    another reason water is better than solvent…. if it were water you could just blow more base over it… just sayin 😛
