Clearcoating headlights
Home / Forums / Main Forum / Paint and Refinish / Clearcoating headlights
- This topic has 3 replies, 2 voices, and was last updated 12 years, 5 months ago by zarbat007.
Hi everyone, hope all is well. :cheer:
I am in the process of clearcoating my headlights. What is the maximum grit I can use for clearcoat to stick? I am thinking P800 dry.
What about P1000? Too fine? (I know in the other thread some members mentioned P800)Also, is it possible to scuff the headlight areas not visible (underhood, around feneders, etc)and spary clearcoat over them? Will the clear stick to the original coating?
Thanks in advance.
July 8, 2012 at 3:57 am #37609You need to watch the P grade sandpaper,P1000 is actually 500 grit.You will be fine if you use 600-800 on an orbital sander and gray scotchbrite the edges.Use some spraynine on them first to make sure they are clean and free from bug guts.Clearing headlights works fine,I have never had a problem doing it this way,you could even spray on some adhession promoter if you want before you clear like sikkens PO.
Just thought I’d post the results. P800 was my final step.
Before:
[URL=http://imageshack.us/photo/my-images/585/dscn0030h.jpg/][IMG]http://img585.imageshack.us/img585/290/dscn0030h.jpg[/IMG][/URL]
After:
[URL=http://imageshack.us/photo/my-images/577/dsc0587q.jpg/][IMG]http://img577.imageshack.us/img577/4715/dsc0587q.jpg[/IMG][/URL]
[URL=http://imageshack.us/photo/my-images/846/dsc0584b.jpg/][IMG]http://img846.imageshack.us/img846/6172/dsc0584b.jpg[/IMG][/URL]
[URL=http://imageshack.us/photo/my-images/708/dsc0591kg.jpg/][IMG]http://img708.imageshack.us/img708/4716/dsc0591kg.jpg[/IMG][/URL]
[URL=http://imageshack.us/photo/my-images/28/dsc0592yg.jpg/][IMG]http://img28.imageshack.us/img28/7859/dsc0592yg.jpg[/IMG][/URL]
Thanks again. :rock
