clearing over single stage
Home / Forums / Main Forum / Paint and Refinish / clearing over single stage
- This topic has 3 replies, 4 voices, and was last updated 12 years ago by Byan Scholz.
- April 5, 2013 at 8:04 pm #42638
In the second or thirth coat of color mix 15% of clear then apply another 1 or 2 coats of clear over the total , take care of decent flash times , like 20 or 30 minutes between coats and there should be no problems.
I love the way a properly done black single stage job looks :dnc , They can look good cleared over to as well. I know with Standox ther blackest black is in a single stage but they also have a basecoat (factory black) called “deep black” I have used it and it is a sweet color, really deep and no yellow brown to it more of a deep dark blue black very dark and briliant :dnc
April 11, 2013 at 5:21 am #42758What I do is use usually medium Hardener and medium reducer with the ss then use slow slow on the clear basically just use a slower hardener in the clear then the ss. Also Helps if use ss and clear that use the same hardener
I’ve done two tri stage pearl white cars now with ss both came out pretty damn nice
