compounding issue
Home / Forums / Main Forum / Paint and Refinish / compounding issue
- This topic has 5 replies, 4 voices, and was last updated 15 years ago by Scott.
hye all..i already done my clear coat on honda ef9..
now i want to polish the clear coat..
my 1st question is do i need to color sanding before compounding?
can i compounding without color sanding?2nd questions, which one is better?
farecla g3, 3m extra cut, 3m fast cut plus..what the different between 3m extra cut and 3m fast cut plus?
thanks :pcorn:
September 13, 2011 at 3:48 pm #32870yes, you need to sand the clear before you buff it. as far as what compound is better… I prefer Meguirs 105
1. You don’t need to colour sand unless you want a show car finish,
or denibbing (sanding dirt nibs out).
If your wanting a show car finish you’ll have needed to put 3-4 wet coats of
clear on or else you’ll burn through the clear when buffing
or get delamination problems down the track.2. Yes you can buff without sanding but it won’t make the biggest difference
unless you spend a lot of time on it and know what your doing.
You should just check out Autopia.org for threads on how to buff.3. I’m guessing fast cut is a coarse compound while extra cut is coarser.
G3 may be the finest compound of all 3.
The finer the less work you’ll need to do to fix swirl marks
but the longer it’ll take to get the finish you want. Tip is to always start with finer
before coarse, then work your way from there to see what works.September 13, 2011 at 6:42 pm #32873well if he just sprayed the clear, no amount of buffing is gonna make it look better unless it gets sanded. its not like its old paint he is looking to restore.
also color sanding is not olny for show car finishes. Some people can apply clear with a grapefruit texture and color sanding helps to smooth it out to match existing finishesWhy would you buff fresh clear witout sanding? its not lacour.. :p
all you would achive is chancing swirl marks in the finish, which you dont want.
cut it with 15oo than 3000, compound than polish the swirlmarks. I use the 3M polishing system but i have heard the Farecla total is a great one step compound/polish. I am looking forward to trying it- AuthorPosts
