compounding problems
Home / Forums / Main Forum / Paint and Refinish / compounding problems
- This topic has 5 replies, 5 voices, and was last updated 15 years, 1 month ago by Stone.
- August 21, 2011 at 4:20 pm #32581
why does my compound always end up smearing and sticking to the paint? I’ve tried everything… is the clear too soft? it been a week altrady
August 21, 2011 at 8:33 pm #32584Are you spritzing with water?what rpm are you running,how long has your clear cured before you polish ,what products are you using?
August 22, 2011 at 6:46 am #32592just sounds like your using way too much compound and the pad is completely loaded with it. the heat eventually burns off the water or lube and it just cakes up. use less. it doesnt have to be a big smeary mess.
August 23, 2011 at 4:16 pm #32608[quote=”jim c” post=22121]just sounds like your using way too much compound and the pad is completely loaded with it. the heat eventually burns off the water or lube and it just cakes up. use less. it doesnt have to be a big smeary mess.[/quote
bingo
