cracked headlights
Home / Forums / Main Forum / Restoration / cracked headlights
- This topic has 11 replies, 7 voices, and was last updated 13 years, 7 months ago by josh.
i wet sanded my headlights with p600 and then scuffed it with a grey pad and scuff stuff. after that i cleaned it with super clean. i used ARC clear coat with plastic primer, fast reducer, and fast thinner. after spraying it, “cracks” appeared. why does that happen? someone please help me
November 14, 2012 at 9:14 pm #39201How about some of the clear bulldog sealer? We polish them only, no clear.
November 14, 2012 at 9:36 pm #39202All you need is a good 2k clear. your jambing clear is likely lacquer and the cause of the cracking. it will not do this with 2k Urethane clear. no need for any AP.
November 15, 2012 at 4:47 am #39219X2, I have used Nason 496-00 in the past with excellent results, never had a cracking problem
November 17, 2012 at 6:03 pm #39274I have no idea what ARC clear is or what plastic primer your using, but almost all the time the adhesion promoter goes on first then clear as normal.
If the product your using is something specific for headlight I could be wrong.
