curing with i/r
Home / Forums / Main Forum / Paint and Refinish / curing with i/r
- This topic has 3 replies, 4 voices, and was last updated 12 years, 9 months ago by nick.
hey ,
just bought a couple of short wave i/r paint drying lamps 2kw each
how effective are these to use
i was told get the panel upto temp with i/r
apply primer ir at bake panel temp 60deg for 30mins as per tds let cool for 10 mins
sand as per usual 500/800
blow dry off and pre heat panel . wipe / tack
apply base as normal apply i/r with panel blowers (water)
clear coat let flash 5mins and i/r for 45mins at 60deg panel temp ?
let cool or shock cool with bucket of cold water!
flatten /polish
Any feedback on this guys ?
AnonymousJuly 31, 2012 at 2:54 am #37746I love the one we have, drying times are much quicker then a regular bake. The metal temp is gets to 60/140f deg within about 2 minutes compared to anywhere from 10-20 minutes if it even hits that temp in a bake booth. Primer (unless your loading it on) for me is around 10 minutes, most clears 15 is more then enough.
tommy
To be honest that sounds like quite long cycle times for short wave i.r.
I always thought I.R. short wave in particular, the selling point was that it was much quicker at drying a panel than a spraybooth was.
I have an old trisk medium wave it probably dries panels in the times you mentioned, but as i say i was led to believe short wave was much faster.
Still a great additon to the shop though, will speed up your jobs big time. 😉
