de beer hs and ms clear
Home / Forums / Product Reviews / Paint Products & Systems / de beer hs and ms clear
  • March 16, 2013 at 7:58 pm #42136
    good morning. i have a problem spraying ms and hs clear, after im done spraying the clear i get thick orange peel or heavy texture therefore, i have to buff the vehicle. when i mix the clears i use the ICRIS software, on MS i use 3% reducer and 8% on HS. also i spray at 30 psi and 75% overlap. can anyone help me solve my problem of leaving heavy orange peel? im trying to leave a mirror look on the car.
    btw, i use an iwata spray gun. thank you
    March 16, 2013 at 8:13 pm #42137
    I spray the HS420 with a GTi pro and T110 air cap, doesn’t lay as flat as MS right away but then flows out fine.
    March 17, 2013 at 3:59 am #42148
    Hey matey, I use the iwata for hs, and gti pro for ms, for the ms I tend to have my settings as, if you open you can wide open then wide it in one full turn, try to spray between 6 to 8 inches away, also I do a 50% overlap and and set the gun round 26 psi, also how many coats you laying down and are you doing one medium first coat or two wets ect, with the iwata I found out that a 1.2 was best for the hs clears same set up but spray at 28 psi, please try and spray on a masking paper or old panel first if your coming to change the set up lol don’t go straight on the the repaired panel for the reason of just in case and oh sh#t that’s not right ha ha
