Engine Block, Epoxy…. or Etch?
Home / Forums / Main Forum / Paint and Refinish / Engine Block, Epoxy…. or Etch?
- This topic has 28 replies, 15 voices, and was last updated 16 years ago by Jayson Munro.
- October 27, 2010 at 1:48 am #24702
I’m weighing my options right now, the block isn’t prepped, I’m going over it with wax and grease remover and red scotch brite right now. I’m worried I won’t have enough bite in the steel which is why I’m considering etch. What do you guys think is the best way to prep this and should I use etch or epoxy?
October 27, 2010 at 3:11 am #24712[quote=”Ben” post=14911]could you soda blast it or something like that to help with abrasion?
Personally, I would just go straight epoxy.
Is the engine disassembled or in pieces? If it is pieces, could you have a machine shop dip it?[/quote]
It’s mostly assembled, The top end is missing, waterpump is attached, took the the distributor off. From what I understand the owner wants the waterpump pained too, bolts and all. I’m leery of blasting the block because I don’t want media in any orifices, from what I understand, the engine has already been rebuilt. Can anyone say @$$ backwards :cens
October 27, 2010 at 3:45 am #24713Tough call. I would say you can’t go wrong with epoxy, but I have never had etch fail on me and it’s been over a decade.
Have you ever over hardened clear on engine parts?
October 27, 2010 at 4:31 am #24715I have done quite a few engine blocks on moth car and motorcycle. I always epoxy then ss on them. Never had one fail
October 27, 2010 at 5:22 am #24719[quote=”painter123″ post=14915]did one about 6 years ago epoxy’d it and then single staged it and it still holding out..:compsmash[/quote]
[quote=”jim c” post=14916]I have done quite a few engine blocks on moth car and motorcycle. I always epoxy then ss on them. Never had one fail[/quote]
How did you guys prep them? The only thing that has me leaning towards etch is media blasting them isn’t really an option and I don’t trust scotch brite. I would rather epoxy them I’m just worried I might not have bit into the block enough and might want some self etching attributes..
[quote=”ryanbrown999″ post=14914]Tough call. I would say you can’t go wrong with epoxy, but I have never had etch fail on me and it’s been over a decade.
Have you ever over hardened clear on engine parts?[/quote]
can’t say that I have, Probably not going to use BC/CC, rep is looking into some products for me
October 27, 2010 at 8:17 am #24732ideally sandblast them after a hot tanking, before machining.
now, I think a good rough scotchbriteing, and possibly a wire brush in the nooks and crannies, then rely on epoxy’s incredible adhesion. I love the stuff.
