Ever herd of metal spray for Rust repair?
Home / Forums / Main Forum / Auto Body Repair / Ever herd of metal spray for Rust repair?
  • September 10, 2009 at 3:55 am #15836
    Is it a Real repair or junk
    http://www.thermioninc.com/arcspray-autoarc150.php
    September 10, 2009 at 4:39 am #15838
    Looks cool, I’ve never seen it before. I’m not big on resto so I don’t come across the latest and greatest. My first thought is extremely skeptical.
    September 10, 2009 at 4:52 am #15839
    I have heard of spray welding before but have never really researched it. not sure if this is the same thing or not
    September 10, 2009 at 6:19 am #15841
    http://www.youtube.com/watch?v=uV-QPTpJaYo
    Hmm I dunno…
    September 10, 2009 at 6:36 am #15842
    well just so happens that a buddy of mine moved to BC to work for the company that has Canadian rights to the Spray weld and it is really cool *** :pcorn: not sure how it would be used in auto body :huh:
    September 10, 2009 at 3:10 pm #15845
    spray welding has been around for a long time. i have seen it used to resurface crank journals on remanufactured cranks where the bearing journals are pitted or too small. they will spray weld more material onto it and return the journal down. is it good…..well it wasn’t the best for that situation because occasionaly it would peel but that is an area of extreme wear and abuse. i would imagine it could work really well on autobody but who knows.
    September 10, 2009 at 6:54 pm #15848
    I have used it too repair shafts in a Jet Boat pump and then had it turned down worked good that was SS.
    I know for a Fact they use the stuff on aircraft and marine applications as well.
    Here’s another one or two
    http://www.tmsmetalizing.com/applications/autoRustRepair.htm
    http://www.rustbusters.com/works.html
    http://www.metallisation.com/index.html
    I guess there’s lots of this stuff ever heard of Jethot the one every one uses to coat there Headers?
    That’s a Flame spray deal with ceramics. cool stuff.
    September 11, 2009 at 1:06 am #15859
    yeah my powdercoater does ceramics like jethot. its just like a regular paint you spray on then bake at around 600deg.
