Fade out
Home / Forums / Main Forum / Paint and Refinish / Fade out
- This topic has 9 replies, 6 voices, and was last updated 14 years, 5 months ago by David Mitchell.
- August 11, 2011 at 5:29 pm #32291
I plan to fix a scrape on corner of my door, repairs easy enough etc, and i understand that i could colour over the local area and clear the full door,
if i wanted to fade out the clear into the rest of the door, how would i achieve this, what products etc.
ive seen it done once and from what i remember to blend in dry edge of clear, the guy thinned down hos clearcoat again, 1:1 with thiner??
August 11, 2011 at 10:42 pm #32313Wetsand your blend area back with a 1500 grit and blend into that area with your clear, take some reducer and mist your blend area to let it melt in then let dry and wetsand/buff out the area. It will last for a while, but down the road it will eventually peel and burn back. But its a quick/easy outta sight outta mind fix.
August 12, 2011 at 3:17 pm #32357thats what i couldnt get my head round, how to have no edge after polishing back the dry edge, how are these smart repair guys doing it then ?? as videos etc that ive watched there not clearing the whole panel ,
August 12, 2011 at 4:06 pm #32359yeah jd thats what i would do, i was meaning like when those smart repair guys would only keep the clearcoat local how do they get rid of the dry edge,
August 13, 2011 at 7:24 pm #32391You’re asking how to perform a particular technique, but nobody seems to want to tell you 😆 Sure we all know it’s not recommended practice, but at the end of the day you want to know, so I’ll tell you how I do it:
Make sure your first coat of clear completely covers the basecoated area. When flashed, apply a second coat going slightly further, and flick the edge a little rather than stopping dead.
Then you need to reduce your clear. Many manufacturers have a fade out blender, but it’s really just a very slow reducer, so if you haven’t got a proper blender, just use the slowest compatible reducer (thinner) you can find.
First off I’ll mix this 50/50 (1:1) with the activated clear I have left and lightly wet the dry edge you’ve created above. If you want, you can then use neat blender (or your slow reducer) to wet the edge that your 50/50 mix has left. Personally I use a rattle can blender for the last step, just because it’s quicker.
Then the important thing is to make sure the area is well and truly cured before you start trying to polish / buff it.
