Fiberglass repair question
Home / Forums / Main Forum / Auto Body Repair / Fiberglass repair question
- This topic has 4 replies, 5 voices, and was last updated 11 years, 7 months ago by Charles Smith.
- May 26, 2013 at 3:58 pm #43258
I have to repair an aftermarket fiberglass hood with scoop. The hood has a small piece missing around the front lip (almost as if a small bite was taken out of it) and hair line cracks around the scoop and sharp angles of the scoop. What is the best way to repair these areas. Should I use resin, resin and cloth, fiber hair, etc.
May 27, 2013 at 3:05 pm #43300The hairline cracks you can just sand out and fill with the fiber putty stuf ( not sure how it´s called in english ) and the missing piece , if it is just a small bit , you can shape also with the fiber putty stuf or with the fiber cloth for bigger areas.
if neccesary you can also reinforce the bonnet with cloth on the inside of the bonnet.
Just make sure all is clean and there will be no problem.May 28, 2013 at 12:12 am #43304Use wide masking tape to form a mold, then use 3 layers of mat style cloth. Brush resin in each layer. Each layer will extend past the previous. Rough up the existing surface, 40-80 grit. Now you got something putty will stick to.
May 28, 2013 at 12:16 am #43305I like using epoxy. You can use it and fiberglass mat or they make a netting material that looks like that screen for drywall. I have been using 3m rigid parts repair system lately, its a little slow but you can put some heat on it to speed it up. You can go to http://www.fibreglast.com and find their white pages and it will explain alot about repairs on fiberglass and composites and all that.
