Fixing scratches and polishing??
Home / Forums / Main Forum / Paint and Refinish / Fixing scratches and polishing??
- This topic has 2 replies, 3 voices, and was last updated 12 years, 7 months ago by Rick Kubicki.
- May 19, 2012 at 11:42 am #36956
This question shows how ignorant I am to all things paint and body… but here goes. I have a 2010 Tahoe with minor scratches and some build up on the front bumper that appears to be bugs, etc, from the last couple of years. How do I get everything smooth and polished PROPERLY? I’ve never known exactly how to properly buff/polish/wax a car, and now I want to learn how to get the scratches out and the bumper fixed up and wax/polish the entire thing. I would really appreciate any answers..
I’ve been watching YouTube videos, but I’m not sure I trust them all. Do I sand with a high grit paper? Is there a cure-all cleaner to get bugs and gunk off of vehicles? Thanks for the help.
Mike
May 19, 2012 at 7:40 pm #36958Start with dawn soap wash well like 2 x. Then get a clay bar kit & follow the instructions, do whole car.depending on the depth of the scratch, most time some heavy cut compound can get them out, for others 1500 is all u need. And b carefully, it doesn’t take much to sand thru. And then wash well again after wards.
May 20, 2012 at 3:23 pm #36964Let the soap and water sit on the bumper, keep it wet for a while to soften up the bug guts. then scrub them away and rinse. An all purpose degreaser may work a little better than soap and water. Some of the bug guts will embed into the paint/clearcoat, a clay bar would be the next aggressive way to remove them. If that dont work then wetsand and buff would be next, I use 2000 grit first , the finer the better chance to not go through the clear and is easier to buff out with compound. Sometimes the bug guts are embedded so far you have to sand and repaint.
