flat black clear coat
Home / Forums / Main Forum / Paint and Refinish / flat black clear coat
  • September 1, 2011 at 7:23 am #32696
    anyone have experience spraying flat black with clear coat? (special clear coat for flat black)
    September 1, 2011 at 7:26 am #32697
    Sure what do you want to know?IMO it is much easier and less work to use a black single stage urethane with a flattening agent added,work smart not hard 😉
    September 1, 2011 at 7:40 am #32698
    basically dont ya just shoot the preflatted clear like ya want it all slick an shiney an let the clear do all the work for ya as it drys :stoned
    September 1, 2011 at 4:51 pm #32699
    I’m with Jayson, flat SS is less work. However, we always do flat clear as we don’t have and SS in the shop so it is quicker than ordering in something that may only get used once or twice a year.
    As Bondo said, shoot is like normal clear. Just doesn’t have to be as wet. Read the tech sheet for it and don’t F*** it up or else you’ll be re-spraying it.
    September 2, 2011 at 1:33 am #32703
    I’m with everyone else as far as using a flat single stage black. You are wasting your time spraying a flat black then a flat clear. The flat result comes from the flat clear only (if you are clearing).
    Or even easier, just spray black primer.
    September 2, 2011 at 3:43 am #32707
    thanks guys..but i want to spray the whole body..can single stage lasting for many years? do single stage paint have UV protection?
    September 2, 2011 at 4:25 am #32710
    Yes of course it does,many oem highway tractors and new chevy truck solid colors are still single stage.A single stage solid color still looks better than bc/cc,as long as you use good products it will last indefinately.
    September 2, 2011 at 6:12 am #32714
    I like the singlestage flat blacks to. I’m going to be recording a vid this weekend spraying a jetski using RM UNO I thing SC02 … I’ve used it before on some other things and its held up a few years so far just fine. It’s pretty simple to spray for sure. I would have to think a flat clear would have better UV protection (compared to a singlestage) but noticed most tech sheets I’ve come across suggest applying an extra coat of flat clear, would lead me to believe that a flattened clear doesn’t hold up as well as a regular one. Just my thoughts. :hunt
    September 2, 2011 at 6:38 am #32717
    im confused with flatting agent. how to mix? cannot wait to watch your new video..hehehe
    September 2, 2011 at 3:23 pm #32721
    I’m sure they’re all mixed different. My glasurit ones I think are 50:50 clear:matting agent then hardened 2:1 (clear/matting:hardener). The preflattened uno (singlestage) just gets hardener and reducer added and ready to spray.
    September 2, 2011 at 6:20 pm #32723
    can i use medium solid clear coat for my project? or i must use high solid clear coat? i heard medium solid is easy to spray but the layer is thin then high solid? it is true?? what the difference is?
    thanks
    September 3, 2011 at 6:47 am #32733
    yeah, if your going with bc/cc be sure to lay the clear as if you wanted it glossy otherwise it just ends up more of a foggy look. :stoned
    September 7, 2011 at 7:07 am #32785
    Be a bit before i’ll have the video up, some pics attached here.
    September 7, 2011 at 11:57 am #32787
    wow..u use ss or matte agent with clear coat? still waiting for your video ..hehe
    September 7, 2011 at 3:21 pm #32789
    that’s singlestage
