Flow Coat
  • August 27, 2013 at 12:24 am #44272
    Out of curiosity.. what is flow coat?
    August 27, 2013 at 1:45 am #44273
    clearing, blocking smooth then reclearing. that second round would be a flowcoat.
    August 27, 2013 at 5:15 am #44275
    been doing it for a while
    beats the heck out of buffing
    August 27, 2013 at 6:10 am #44276
    On the topic of flow coating, do you guys flow coat with High solid clears?
    I spray sikkens autowave(waterbase line) and clear with superior 250, ive tried flow coating once with it, but it doesn’t seem to be worth the effort.
    August 27, 2013 at 7:40 am #44277
    I also use autowave and superior 250.Its the same as any other clear,sand it with 600-800 wet or with an orbital plus interface pad apply 2 more coats of clear.I have done it many times in the past with 250 with great results.
    August 27, 2013 at 4:08 pm #44279
    You guys don’t overthin your flowcoat?
    Using a 2:1 clear I’d normally add 15% to 20% thinner. Bit trickier with the 4:1 clears but 10% seems to be OK..
    Have to watch the runs, of course, but only need one coat.
    August 27, 2013 at 4:21 pm #44281
    Yeah.. that happened to me when I painted my Uncle’s GSX-R
    Although it had a lot problems..
    Cratering, fish eyes, runs etc.. but I color sanded the whole thing and added a flow coat.. few minor runs.. but I got almost mirror finish from it..
    At the moment I spray 2:1 + 10% reducer to get a more even finish and allow the clear to flow out nicely..
    I hope I can get a better finish.. i.e. factory VW finish and better.. with my new gun..
    I have a make shift small paint booth that is mobile.. and almost always get no dust or particles.. I have a carpet on the bottom that serves as wet bed retaining the particles..
    August 27, 2013 at 6:15 pm #44282
    I dont get it really, the point that is ??
    Unless it is a show vehicle or a very high end vehicle
    Seems a lot of extra work + Material + Energy + creating a bottle neck
    August 28, 2013 at 12:19 am #44285
    nick, definately not a procedure for a normal production shop. for me almost everything is flowcoated but very rarely do i ever do a single color job so i need to flow coat anyway for a smooth finish that you cant feel the paint edges on. some stuff is cleared 2,3 or 4 times. on most restorations i do though as well as all the other shops i know of that do nice restorations, they all flowcoat unless the customer is on a super tight budget or timeline.
    August 28, 2013 at 12:46 am #44286
    [quote=”suprarztt” post=32962]On the topic of flow coating, do you guys flow coat with High solid clears?
    I spray sikkens autowave(waterbase line) and clear with superior 250, ive tried flow coating once with it, but it doesn’t seem to be worth the effort.[/quote]
    i dont over reduce
    but hey im using a w400 :dnc
    what r u spraying with
    i bet it begins with an S
    August 28, 2013 at 3:17 am #44289
    Nick I only do a sand and reclear on restos or something high end like a complete on a lexus or mercedes.For the regular collision jobs 2 coats of superior is all that is needed and then its still too shiny.
    Reckless spare us the brand loyalty bull shit,if you don’t like sata and the only guns that work for you are iwatas and platinums all the power too ya,99% of the guys here can get a great job with whatever high end gun they pick up.
    August 28, 2013 at 4:48 am #44290
    i use a lph-400 but i dont think its a gun problem. I’ve also used sata’s too.
    Im not saying it doesn’t look good, but maybe im just expecting too much.
    August 28, 2013 at 11:44 am #44292
    a second clearing will most often result in virtualy no die back compared to the first session it can also be done without scuffing the fist session back if done within the first 24 hours as it will crosslink”sherwin williams have recomendation for this to cure solvent pop issues ” but most will scuff first ,my method is to DA the first clearing with P400 then use thinned out product through a fine tipped gun usualy a 1.2 or have my larger set up choked back ,imo the reason why a second clear session maintains a better gloss is the first has sealed everything and stopped the base and primers from acting like blotting paper
    August 28, 2013 at 12:28 pm #44295
    Ah I get it now.. so what I did was add a flow coat.. OK
    btw.. I did a superb flow coat with a $40 china gun.. so I don’t think it is the gun..
    August 28, 2013 at 5:42 pm #44299
    [quote=”Jayson M” post=32975]Nick I only do a sand and reclear on restos or something high end like a complete on a lexus or mercedes.For the regular collision jobs 2 coats of superior is all that is needed and then its still too shiny.
    Reckless spare us the brand loyalty bull shit,if you don’t like sata and the only guns that work for you are iwatas and platinums all the power too ya,99% of the guys here can get a great job with whatever high end gun they pick up.[/quote]
    hey no cussing on this forum
    take that back to the other cult forum
