For the UK guys
Home / Forums / Main Forum / Paint and Refinish / For the UK guys
- This topic has 11 replies, 4 voices, and was last updated 11 years, 9 months ago by ryan brown.
- March 20, 2013 at 4:12 am #42270
Any of you guys ever use the T110 aircap for the GTI Pro? If so what are your thoughts?
March 20, 2013 at 10:08 pm #42278I use it for HS and UHS clears, which I believe it was mainly developed for.
I think its very good, better than the T2 for HS and UHS clears. I still use the T2 for Glasurit single stage though.
What are you thinking of using it for?
March 20, 2013 at 11:01 pm #42281I bought it for the “applies like glass” claims, which It can, depending of what you’re using it or and how you’re using it.
Having said that, I can always lay flatter with it compared to the T2.
I use A DeBeer HS for the quality jobs and I’m trying out a cheaper MS that the suppliers shift loads of in my area for the cheaper jobs.This was only a light cut and buff after the 110 with the HS
[IMG]http://i195.photobucket.com/albums/z61/starbar77/1AC35E52-FBEE-4DB0-A25B-4D91D9117DFA-2601-0000015133B40A89_zps6a0e9bd0.jpg[/IMG]Gun finish in the MS using the T110
[IMG]http://i195.photobucket.com/albums/z61/starbar77/8C3AA054-3AD4-40D7-A1B4-1D5BC9D31C0F-1046-00000099B573B989_zps6482db92.jpg[/IMG]March 20, 2013 at 11:22 pm #42282nice! how much is the t110 cap or did u buy the gun with that set up?
March 20, 2013 at 11:46 pm #42285[quote=”johnmaloney88″ post=31133]nice! how much is the t110 cap or did u buy the gun with that set up?[/quote]
£81 iirc?
March 21, 2013 at 2:36 am #42296[quote=”johnmaloney88″ post=31139]where did you buy it from? thanks[/quote]
I just got it from the local motor factors, Dingbro. They have a huge branch with a big paint dpt.
Sure, I could have got it cheaper online but it was on the shelf and if there ever a problem they’ll sort it out direct with the manufacturer.March 21, 2013 at 3:56 am #42298Thanks guys. I recently got one and have been using it lately. I really like it also. It lays on very flat coat of paint on and also has a soft spray pattern which I like.
Just trying to get a feel for some others thoughts on it.
March 22, 2013 at 11:37 pm #42352I like the soft spray pattern too although I wish it were taller like an Iwata.
The T2 or any other Gti Pro aircap is no bigger either.
Apart from that they’re great.
I paid around £80 for my T110 cap from spraygunsdirect.com, they are local to me so I go to their shop when I want something. Very knowledgable and helpful folks (especially Chris)
March 23, 2013 at 12:55 am #42356I use spraygunsdirect also. They ship to the States pretty fast. 3 day shipping to my door.
The more I use the 110 the more I like it. The US version of the GTI Pro, the Tekna seems to have a little larger spray pattern to me. Although I don’t mind it as I spray pretty close so all patterns are small! 👿
March 25, 2013 at 11:53 am #42411Interesting about the teknas having a larger pattern. I wonder if the tekna aircaps fit gti pros?
I spray quite close too so maybe wouldnt make much difference to me.
March 25, 2013 at 9:23 pm #42416There is an air baffle difference. Just stick with the pros, there isn’t enough difference to worry about it
