Getting solid colors in Onyx flat
Home / Forums / Main Forum / Paint and Refinish / Getting solid colors in Onyx flat
- This topic has 7 replies, 6 voices, and was last updated 13 years ago by W.
from what i saw when a paint rep was spraying waterborne it needs to be wet, to the point where it looks horrible? then when it dries it then comes to life
but then he was using a spray gun that begins with the letter i with the orange cap i cant call the name cause my post may be deleted.
dont know what pressure he was spraying with
you may be spraying a little too dry?August 30, 2013 at 3:24 am #44329A few thoughts,are you using 125 micron filters?You might try adding more waterborne reducer,lower your pressure a bit,and put it on a little wetter.Not all waterbornes are the same but this might help.Has it been hot and dry where you are?A 1.5 has helped in my tekna when its over 80F
September 23, 2013 at 7:25 am #44606When they introduced Onyx to us our rep recomended reducing solids 100%. If you’re in a dry low humidity area you could try HB004.
