Gun issue
Home / Forums / Main Forum / Paint and Refinish / Gun issue
- This topic has 8 replies, 5 voices, and was last updated 13 years, 6 months ago by Eldon Bennett.
- December 5, 2012 at 6:17 am #39677
I was painting jambs on my 67 Firebird tonight and noticed a little skip in the paint every once in a while. When I was cleaning the gun between sealer and base coat I looked down in the cup as I was spraying thinner through it and it was bubbling back into the cup. Every time the bubbling stopped it skipped a little in the spray fan.
What causes this?
This is a cheap gun that I have had for a while and it has painted very good in the past. It is a Vapor gun 1.4 tip, that I bought from the local paint supplier.
I know, and before you say you get what you pay for, it has painted two cars very nice to this point.So can someone out there help?
Thanks
EBDecember 5, 2012 at 7:33 am #39684or take the air cap off and try tightening the nozzle a little more. sometimes if they arent cranked down enough they will suck in air
December 6, 2012 at 6:01 am #39695I agree with ding, same thing happened to me and it was the fluid tip, it was loose
December 6, 2012 at 7:10 am #39703Thanks to everyone for the feedback.
I found that the packing nut was loose and the air cap hole where a little clogged.
I tightened the fluid tip and have not used it yet. I will test it on Friday. The big day is Saturday. The jambs are all painted and ready for final paint.
Thanks
EBDecember 7, 2012 at 5:23 am #39720I tested it today and it works perfect. Thanks for all the help.
EBDecember 9, 2012 at 4:14 am #39760Thanks to everyone on this. I painted her today and it went perfect. The gun worked perfect.
I would like to post a picture. What is the best or should I say easiest way to post pictures on this site. I took pictures through the complete process.EB
