Gun Setup
Home / Forums / Main Forum / Paint and Refinish / Gun Setup
- This topic has 3 replies, 3 voices, and was last updated 14 years, 10 months ago by David Mitchell.
- October 31, 2011 at 3:08 pm #33939
can someone explain the best fluid tip, air pressure make and model of gun to use for , primers, base, clear etc.
also diferent set up for solvent compared to waterbase, if any ?
October 31, 2011 at 4:25 pm #33940Whats the best car?
What your asking is going to be open to a lot of different opinions. There is no best gun or setup, it’s what is best for the material your spraying and your own comfort level. All high end guns are capable of leaving a nice finish. What works for one brand of basecoat may not work for another. You would be better off figuring out what paint you want to use then asking this question. I like a 1.2 nozzle for some clears and all the way up to a 1.4 for others.
November 1, 2011 at 3:46 am #33947Look on you tube for a video by Brian Lynch.
It’s an excellent starting point.
http://store.airbrushaction.com/products/DeVilbiss-Spray-Gun-Handling-Techniques.html
