guys help me decide on new gun
Home / Forums / Main Forum / Paint and Refinish / guys help me decide on new gun
- This topic has 15 replies, 7 voices, and was last updated 15 years, 3 months ago by Andy Taylor.
ok i need a new base gun and hope you guys can advise me what to get ?
atm i have 2 devilbiss gti s both 1.4s and use pro-spray or ppg dbc
problems i have is i can never get it to lay down smooth and un blothchy looking and its really pissing me off….especially silvers lol
i have no problems with clear as i use a sata 2000 hvlp but dont want to start mixing guns …
so looking to treat myself to a new gun
so looking at
1. devilbiss gti pro
2. sata 3000
3. iwata w400
4. anything else
thanks
tommy
January 15, 2010 at 6:30 am #18655I’m guessing you are from the UK or Australia? The Tekna and GTI Pro are the same. Any of them would be a good choice. What product are you spraying?
January 15, 2010 at 3:10 pm #18660The GTI Pro gave you away! You can’t get them in the US or Canada. The Tekna is based off the GTI Pro though.
If you were going with Iwata I would get the new WS-400. It will be far superior to the W-400 you have available over there. Maybe Andy will chime in but he just got the WS-400 and seems to love it. For anybody in the US the W-400 you buy over here is a LV model with the wedge cuts in the nozzle. Everywhere else it isn’t. They still sell the older conventional model. I have both and the LV works much better.
If it was me I would use the Sata as a basecoat gun and get the Iwata or a Sata RP as a clear gun. They will both lay clear out very smooth.
January 16, 2010 at 9:23 pm #18712Hey Ryan, which do you like better for clear… the w400lv or the LPH400? How do they compare?
January 16, 2010 at 11:01 pm #18713W-400lv hands down. Uses less paint and leaves a better finish. If you have to spray a true High Solids clear the LPH really struggles. With a MS clear the LPH does a good job but I think the W-400 has the edge.
I have both guns and I never reach for the LPH for clear.
January 18, 2010 at 8:53 am #18751Thaks Ryan, I have used a sata NR2000 for years and decided I needed a new clear gun so I bought a CVI about a year ago and used the comp cap. I have never had so many problems with runs in my life 👿 So I bought the LPH400 and have had very good luck! So… I was just wondering if the W400LV would put out more material being that its a compliant gun, I would be getting runs again. How does the W400LV compare to the CVI?
I have used a 3000RP with a 1.2 on a job or two and it worked really good!January 18, 2010 at 3:58 pm #18752I also have a CVI. There is no comparison between the two for clear. I can get a nice job out of the CVI but I have got to cut back on my material alot. The W-400 puts it on slicker and with less effort.
Out of all the guns I own I only use my RP or my W-400 for clear.
January 19, 2010 at 12:02 am #18765[b]ryanbrown999 wrote:[/b]
[quote] If you were going with Iwata I would get the new WS-400. It will be far superior to the W-400 you have available over there. Maybe Andy will chime in but he just got the WS-400 and seems to love it.[/quote]
Better late than never :woohoo:Yes, I’m totally loving the WS400 clear gun I’ve got. All being well there’s a guy from Iwata UK coming to see me tomorrow – hopefully packing the base gun for me to try too. I had a guy working for me briefly on the prep side, and he owned one (WS400 base), and said it was the best base gun he’d ever used. Coming from a background of 20 years painting with SATA and Devilbiss, it must be pretty good.
Let you know how it goes, but here’s what the Clear version can do:
[URL=http://i321.photobucket.com/albums/nn385/Duluxdude/Work/WS400-01.jpg][IMG]http://i321.photobucket.com/albums/nn385/Duluxdude/Work/th_WS400-01.jpg[/IMG][/URL]
Not bad for my first ever go with it using a HS clear 🙂
January 19, 2010 at 2:57 am #18766[b]Andy T wrote:[/b]
[quote][b]ryanbrown999 wrote:[/b]
Not bad for my first ever go with it using a HS clear :)[/quote]
Heck thats just a fender andy. You can make somethin that small that smooth with an airbrush :whistle: :whistle: 😛- AuthorPosts
