head lights again!! referbing them??
Home / Forums / Main Forum / Paint and Refinish / head lights again!! referbing them??
- This topic has 16 replies, 12 voices, and was last updated 16 years, 1 month ago by MoCoke.
hi guys i read a post about refurbing head lights sanding them down and spraying them with clear but where they glass or plastic????
i have just brought a merc e class and the headlights are shagged!! but there plastic i didnt want to start preping them if you can only do them to glass ones
any help would be great thanks
July 26, 2010 at 8:54 am #23299i know you can sand down with some 3000 grit (trizact system) then buff back out. i’ve never heard of anyone clearing their lights.
I do headlight referbs where I work but only on plastics. When the plastic starts dulling out or turns yellowish due to oxidation I usually wetsand them with 800 grit and work my way to 2000 grit and finally finishing it off with 3000. Then I just compound them and bam!.. back to new again. Unfortunately.. it only last about 6 months or so before it starts to dull again.. which is what I tell my customers so they know. I haven’t ran across a product that can last longer than that.
[b]Kudos,[/b]
JayJuly 26, 2010 at 2:59 pm #23317Sand and clear them, it will last. I have done it for a few years now with very good luck.
July 26, 2010 at 3:49 pm #23323yup, just sand them with 600-800 and put 2 coats of clear on them. i do atleast a few sets a week here. they will last for years.
July 28, 2010 at 5:14 pm #23371Here are a set of headlights a friend painted a while back [img]http://www.refinishnetwork.com/media/kunena/attachments/legacy/images/paintjob.jpg[/img]
Attachments:July 28, 2010 at 5:16 pm #23373Have a great week! [img]http://www.refinishnetwork.com/media/kunena/attachments/legacy/images/Have_a_great_day.jpg[/img]
Attachments:July 29, 2010 at 8:12 am #23391give me a call brad i can gloat ta ya about dealing with the epa some an yes im having a great week now ….. that all the smokes cleared good times ahead :cheers
August 2, 2010 at 3:23 pm #23473no, its not necessary. you will have a better bond with the clear direct to the plastic. they are usually polycarbonate, not a hard to stick plastic.
hi guys i done one side they look better im going to redo them as after the second coat they cracked up like a solvent attack?? maybe i didnt leave it to flash long enough!! but great inprovement anyhow
have a look
[IMG]http://i328.photobucket.com/albums/l342/big_G_essex/290720101038.jpg[/IMG]
[IMG]http://i328.photobucket.com/albums/l342/big_G_essex/290720101037.jpg[/IMG]- AuthorPosts
