Help needed Installing Anchor Pots???
Home / Forums / Shop Operations / Help needed Installing Anchor Pots???
- This topic has 3 replies, 3 voices, and was last updated 14 years, 11 months ago by KoN.
I am trying to figure out how I can get a few anchor pots installed in my cement floor after I drill out the 3.5″ hole? I know that I need a pot press but were can I find one to rent or purchase I cant seem to find anyone with this press here where I live,anyone here have an alternative to installing them without having to re-cement maybe like a 4×4 piece of wood and sledgehammer?Yes very green to this line of work but I would really like to learn.Thanks in advance for any replies[IMG]http://img16.imageshack.us/img16/8776/11538.gif[/IMG]
January 13, 2010 at 9:08 am #18600You might check with someone in your area that sells frame equipment. They might do it for a reasonable charge or get you to some one else that can help.
January 14, 2010 at 5:13 am #18610I have put wood blocks or steel plates on the edge of the pot, once it is in the hole and stood on the plates and used my big slide hammer to pull the chain up and set the wedge. It does not take much to set them. Once they are set, make a pull and it will set them even better.
brad
