help!! new bumper
Home / Forums / Main Forum / Paint and Refinish / help!! new bumper
- This topic has 1 reply, 2 voices, and was last updated 14 years, 11 months ago by Scott.
hye..
i want to spray new plastic bumper..need to apply adhesion promoter.
1st question: do i need to sand the bumper before apply adhesion promoter?
2nd question: after applied adhesion promoter, i need to sand the adhesion promoter?
3rd question: primer surfacer over adhesion promoter..it is needed?
thanks
Is the plastic bumper primed? if so there is no need to apply ad. pro. just lightly sand with 800 or equivlant and apply sealer with a flexable additive/base/clear.
If the plastic bumper is just bare plastic it will need to be first cleaned with a plastic cleaner to remove any release agent from the mould it was made in. Sand the bumper with 800 or equilvant than apply a light coat of adhesion promoter,no need to sand it just let flash for 10 mins apply a sealer with flex add/base/clear
:weights- AuthorPosts
