Hood with lot of stone chip
Home / Forums / Main Forum / Paint and Refinish / Hood with lot of stone chip
  • July 4, 2010 at 3:47 pm #22268
    Hi all!
    I have a hood with a lot of stone chip on. May be i’ll sand all the hood for fixe that. Is it enough use 2K Urethane primer or Epoxy Primer? Need a sealer too? I use Nason Dupont (421-19) product. In doc:
    [code]No sealer is required but may be sealed with
    Nason® SelectSeal™ 422-48 or any other 2k
    Nason® Sealer.[/code]
    thanks
    July 4, 2010 at 6:09 pm #22274
    Epoxy > 2K Urethane primer > Sealer > Base > Clear
    [IMG]http://img.photobucket.com/albums/v345/zsolo/Cars/2004%20Camry/IMAG0181.jpg[/IMG]
    [IMG]http://img.photobucket.com/albums/v345/zsolo/Cars/2004%20Camry/2004-camry.jpg[/IMG]
    [IMG]http://img.photobucket.com/albums/v345/zsolo/Cars/2004%20Camry/IMAG0211.jpg[/IMG]
    :cheer:
    July 4, 2010 at 7:59 pm #22280
    if it were me, I would strip the hood (with a chemical stripper, such as Tal-Strp) down to the bare metal. Quickly sand the hood with 180-320 with a DA sander. If there are no dents, then I would put it straight into the booth.
    Then etch it or use DTM Epoxy primer, then your 2k urethane sealer…base/clear. All wet on wet.
    July 5, 2010 at 12:23 am #22304
    Thanks a lot guys!
    July 5, 2010 at 1:20 am #22311
    Depending on what it is, sometimes, it’s just better to replace it with an aftermarket one
    like i should have on this Camry. :wak
