how to make sure that your gun is spraying right.
Home / Forums / Main Forum / Paint and Refinish / how to make sure that your gun is spraying right.
  • January 19, 2011 at 6:37 am #27424
    if you ever wonder if your gun is spraying properly, well last night i decided to do a quick how to. i include two photo’s. one from a ppg training manual, and an actuall example.
    the photo of the manual exp. with intrustions.
    [IMG]http://i40.photobucket.com/albums/e246/1terpfan/z71/IMG-20110117-00027.jpg[/IMG]
    now the true to life exp..
    [IMG]http://i40.photobucket.com/albums/e246/1terpfan/z71/IMG-20110117-00024.jpg[/IMG]
    ah crap you know what i screwed uped big time. i overlooked the part where it said to tape a piece of paper to the wall.
    :compsmash :compsmash :compsmash :deadhorse :deadhorse :deadhorse :deadhorse :teach :teach :teach :rock
    hope ya’ll learn something, use a smaller gun for those hard to reach area’s. because size matters.:p
    January 19, 2011 at 8:03 am #27428
    Well, I guess my runs aren’t so bad afterall…
    January 19, 2011 at 8:09 am #27429
    Maybe try some pepto-bismol Ben :rofl :rofl :stoned Good post Lild :clappy
    January 19, 2011 at 10:15 am #27434
    Tell you what I learned from what bondo told me a month ago…it’s not always wide open on OVERALL or panel painting. Some times you need to adjust differently. I was having a problem with my Sata. I cleaned up the fan a fuzz, Increased the pressure to 30 (HVLP), and slowed down a tad….waalaa….success!!! :rock :rock Some pros might have thought there was hardware issues and a need to go replace very expensive parts. so glad I listened to the pro bondo and applied it to my application…whew!!!! Saved me hundreds of dollars!!! Thanks!! :pcorn:
    January 19, 2011 at 4:41 pm #27437
    [quote=”timbo” post=17360]Tell you what I learned from what bondo told me a month ago…it’s not always wide open on OVERALL or panel painting. Some times you need to adjust differently. I was having a problem with my Sata. I cleaned up the fan a fuzz, Increased the pressure to 30 (HVLP), and slowed down a tad….waalaa….success!!! :rock :rock Some pros might have thought there was hardware issues and a need to go replace very expensive parts. so glad I listened to the pro bondo and applied it to my application…whew!!!! Saved me hundreds of dollars!!! Thanks!! :pcorn:
    [/quote]
    If I’m not mistaken It was you that wanted to replace the expensive parts :wak
    January 19, 2011 at 9:15 pm #27442
    Nope it was me that said that :stoned He said he had a bottom heavy pattern,usually means your fluid tip is damaged or your air horns are dirty.Turning the fan in to clean up the edges is one thing,but to cure a top or bottom heavy pattern is asking for problems.
    January 19, 2011 at 10:06 pm #27443
    [quote=”Jayson M” post=17368]Nope it was me that said that :stoned He said he had a bottom heavy pattern,usually means your fluid tip is damaged or your air horns are dirty.Turning the fan in is just compensating for another problem.[/quote]
    Amateur :p :rofl :rofl :rofl
    January 19, 2011 at 10:14 pm #27444
    I like turning my fan in, I am trying to compensate for something I guess! :blush:
    Some of these pros like jayson think they know everything about painting, I’d be willing to bet he doesn’t even paint cars for a living, probably just sits at home all hours of the night and trolls this site. :rofl
    January 19, 2011 at 11:10 pm #27445
    Damn ….guilty as charged,the secret is out :clappy :stoned
    January 20, 2011 at 3:31 am #27448
    [quote=”Jayson M” post=17371]Damn ….guilty as charged,the secret is out :clappy :stoned[/quote]
