Infra red primer between coats ?
Home / Forums / Main Forum / Paint and Refinish / Infra red primer between coats ?
- This topic has 5 replies, 4 voices, and was last updated 10 years, 3 months ago by Carl.
- December 28, 2014 at 11:48 pm #48128
It really depends what the weather is doing where a guy lives.In the summer months the shop is warm and flash time is minimal.In the winter even though the shop is warm I like to put the infrared light on the panel to get the metal temps up before I prime,then after I apply a coat put the light back on.I keep doing it this way for each coat until I am finished,it really cuts down on time and shrinkage.If a person is careful with distance you won’t have to worry about possible blistering and solvent pop.Nice gentle heat is all you need.
Most infra red lamps have a flash off function, flash off function can be used for drying between coats.
Over the years I have used medium and short wave lamps, Last year i bought a new shortwave model, they are a major improvement on medium wave models.I always bake my primers, even if they have sat overnight i would still put the lamp on them for ten or fifteen minutes in the morning, if the primer is fully cured, i find there is much less chance of any sinkage etc.
I have two lamps a three cassette model and single cassette model they are used daily and i wouldnt be without them lol.
