Iwata lph 400 lv
Home / Forums / Main Forum / Paint and Refinish / Iwata lph 400 lv
- This topic has 9 replies, 7 voices, and was last updated 15 years, 9 months ago by Adam.
- March 17, 2009 at 11:40 pm #13425
What a great find, this site. Just got an Iwata 400 HVLP. Used a Devilbiss GTI Millenium for the last several years. Used the Iwata for clear twice so far. I shot Diamont DC 92 and Dupont 72500S. The Iwata is slower than what I am used to but it does save a lot of material. I shot at 16 PSI as recommended and tried to keep it about 7 inches away but that is hard after 20 plus years of about 2 times that. The problem I have is a significant orange peel. I have the proper reducer temp et cetera. I tried to get too close and got a hanger where I went too slow and got too close. I have a 1.4 tip and had the material screw out pretty far. Any ideas? For my next trick I am going to use about 20 or more PSI and stay at the 6-7 inches. It was all I could do not to get a Sata 3k RP but went with Iwata based on word of mouth. I’m looking forward to being involved in this site.
March 18, 2009 at 12:05 am #13426kicking up the air ta 18 an staying close will help ya with the peel tremendously;) the iawata dont like ta be that far from the pnl myself im an rp man but also got alota respect for the iawata an what the can do i think theres a vid here of me shooting an iawata on the kids honda but i had the pressure a little on the high side welcome to the site!!
March 18, 2009 at 12:10 am #13428btw dont shoot 3 coats back ta back like that :blink: :blink: :blink: or where a flannel shirt we were just seeing how far we could push things in that vid
AnonymousMarch 18, 2009 at 1:20 am #13429Welcome to the site & look forward to your participation.
I’ve found it incredibly difficult to spray at Iwata’s 16 psi recommended pressure. I’ve always bumped it up to at least 25 to get an ideal finish. I did spray at 16 for a while when I first got the gun but started bumping it up a bit from their. One other thing is Iwata recommends the pressure being set with the gun spraying full trigger, the pressure will drop a bit when the materials going. I haven’t had the chance yet to spray with a 1.4 with this gun but I think I’m missing out, especially with some of these thick glasurit clears.
I’ve never sprayed that dupont clear but I can remember the DC92 that sprayed like water, I’d have to set up drip buckets under my paint jobs :-). It did flow nice, but a bit challenging to spray.
March 18, 2009 at 2:55 pm #13447A 1.4 is a little big for 72500. It will work fine but you need to bump your pressure up as everyone else said. I am more along the line with Jimmo, I would try around 23-25 psi. Also try dialing your material a little, maybe 3 to 3.5 turns out from closed.
I couldn’t comment on DC92. The only experience I have with that clear was a demo I did years ago. The only thing I remember was a car with runs! - AuthorPosts
