iwata replacement parts
Home / Forums / Main Forum / Paint and Refinish / iwata replacement parts
  • August 23, 2011 at 5:00 am #32604
    Need any recomendations on who to go to for replacement parts on a LPH 400. I have one that I want to convert from a 1.6 fluid nozzle to a 1.4. If what I understand is correct I will need both the fluid nozzle and the needle. Please correct me if I am wrong. Thanks in advance for the help.
    August 23, 2011 at 9:25 am #32606
    Hi there 1.6mm is a pritty big setup.. What are you going to use the gun for base or clear?? my prefrence is 1.3mm for base and 1.4mm for clear. But still can get good results with 1.3 for clear some high solids dont like it though.. Yes you will need to change needle aswell expect to pay a couple of hundy for a brand new setup..
    August 26, 2011 at 8:51 pm #32642
    Go to their forum and ask Hub
    http://www.asetusa.com/phpBB3/viewforum.php?f=11
    August 27, 2011 at 5:22 am #32646
    That’s interesting because when I went from 1.3 to 1.4 I called Iwata directly and the rep I spoke with said I only needed to change the nozzle and there was no need to change the needle. Now going from 1.6 might be a different story. But my gun shoots fine.
