jambing a great lacquer job what can i use too
Home / Forums / Main Forum / Paint and Refinish / jambing a great lacquer job what can i use too
- This topic has 6 replies, 5 voices, and was last updated 11 years, 11 months ago by paul.
I am jambing a 65 goat that has a wonderful lacquer resto from the late 80’s . Who ever did it …did a great job…except .. they didn’t do the door jambs , hood edges , fender jambs..etc.
We sanded to within 1/2 inch from edges which were then wet sanded to feather. After a application of 2k primer we have 1/8th inch to 3/16 of black lacquer before we roll up and over the edges of fenders and quarters .
Lacquer has a tendency to wrinkle , lift , get gummy and other bad stuff when coated with a base /clear ( in my experience ) what do you guys suggest as a barrier between the two ? I would prefer a black sealer and have many types of paint suppliers to chose from. thanksMay 25, 2013 at 11:58 pm #43251Epoxy mixed as a sealer would be my choice.Not really sure I understand where your cut off point is but it would be better to stay about an 1/8 inch away from the edge of the jamb to avoid the outside of the car.
May 26, 2013 at 2:53 am #43254I would suggest a fast dry, cure, product. How about a 30 min clear. I would avoid a wet application, don’t give it time to bite in and wrinkle. I’m not sure exactly where your coming from, but I paint jambs with quick clears. For me, I can tape over the jambs quick for exterior paint. You want to protect the existing exterior, MY rule is , easier to keep overspray off than to clean it off later.
[quote=”billgaino” post=32051]I would suggest a fast dry, cure, product. How about a 30 min clear. I would avoid a wet application, don’t give it time to bite in and wrinkle. I’m not sure exactly where your coming from, but I paint jambs with quick clears. For me, I can tape over the jambs quick for exterior paint. You want to protect the existing exterior, MY rule is , easier to keep overspray off than to clean it off later.[/quote]
I agree with Jayson. Epoxy is the best product. Unless you are hard lining it, the base would be sprayed just a hair further out than the sealer. Is this where you are concerned about any wrinkling?
You could try using a water base coat. Probably wont wrinkle the old lacquer(or be a lit less likely to anyway).
May 26, 2013 at 9:46 pm #43260[quote=”ARTSPRAY” post=32056]at the first sign of any reactions i add a small peercentage of 2K activator to my base[/quote]
Once you have “signs” of a reaction its already to late.Activating your base is a good idea and can’t hurt in this situation but the reducer is what will cause the lacquer to reflow/wrinkle.Like was mentioned before epoxy mixed as a sealer(thinner viscosity), sikkens basefix,or over reduced clear(100-150%)to put down as a barrier coat to prevent wrinkling is the best choice.Over reduced clearcoat will work as a wetbed for blending or to help avoid reactions,one quick light coat with some flash time and go right to base.- AuthorPosts
