job tracking resource
Home / Forums / Shop Operations / job tracking resource
  • February 3, 2012 at 8:04 pm #35717
    Last month I moved into the Shop Foreman position and things are good but I believe they could be better.. So I am just looking for some better ideas or resources for tracking jobs in process.
    We average $300,000/month and generate around 175 repair orders per month
    Thanks
    February 4, 2012 at 4:36 am #35719
    You are generating 175 repair orders per month and $300,000 and you don’t have a way of tracking your jobs? Or did I misunderstand you?
    February 4, 2012 at 8:36 am #35720
    If you want to be cheap, you could set something up in MS Excel and manually enter the jobs as they arrive then track them that way…or a very large dry erase board
    Otherwise there are some software programs that can work with your estimating software. What are you using for estimates?
    February 6, 2012 at 6:22 pm #35755
    [quote=”thenextlevel” post=25050]You are generating 175 repair orders per month and $300,000 and you don’t have a way of tracking your jobs? Or did I misunderstand you?[/quote]
    you misunderstood
    February 6, 2012 at 6:27 pm #35756
    [quote=”Ben” post=25051]If you want to be cheap, you could set something up in MS Excel and manually enter the jobs as they arrive then track them that way…or a very large dry erase board
    Otherwise there are some software programs that can work with your estimating software. What are you using for estimates?[/quote]
    I use the dry erase method right now.2 boards.. But it gets a little overwhelming :silly:
    We primarily use CCC one.. but also have Audatex..
    Our dealership uses ADP management..
    February 7, 2012 at 3:26 am #35759
    I’m kind of in the same boat as far as moving into the position and knowing there is room for improvements but not knowing where to start.
    We use Audatex online. It was setup at this shop before that they used Google Docs which has it’s own form of a spread sheet, word processor, etc. I have one spreadsheet with the name, insurance company, refinish hrs, body hrs, total hrs, date in, date out and days in the shop. from there i set it up to automatically figure my avg rf hrs per job, body hrs per job, cycle time, touch time, etc.
    i’ve got another spreadsheet setup to input my tech’s hrs, they’re output and efficiency.
    in order to access google docs you have to have a gmail account, which our shop uses as our email address anyway.
    February 7, 2012 at 4:11 am #35761
    check this site out for affordable solutions
    http://www.bodyshopsolutions.com/WordPress/
    February 7, 2012 at 7:33 am #35771
    Well, if it were me, I’d get rid of CCC and just use Audatex and/or Mitchell. CCC isn’t available up here, but I am familiar with their estimates through General Motors, and they make me 😡
    Mitchell has a tracking program. There is also AutoFocus (avaliable through Audatex). It is some fancy software for management/tracking and is compatible with all estimating software. I have not used it, but know a local dealer group that is using it in their bodyshops. I have heard good things about it and they are having success using it with Mitchell and Audatex.
    February 7, 2012 at 10:55 pm #35775
    thanks for the info regarding google docs Mikespaint
    And thanks Ding for the link.. been a while since I’ve been over there
    Sorry Ben CCC One isnt going anywhere around here. Getting ready to be done with Audetx the end of next month…. but I’ll check out the AutoFocus before Audtex goes
    Thanks for all your replies
